Question about Ebac HD880 Dehumidifier
Flashing red light - Ebac HD880 Dehumidifier
Red Lite is flashing, unit will not turn on
if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
Aug 24, 2015 | Amana D950EP Dehumidifier
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
Not running- CH 24 code on the Humidity setting & empty bucket red light flashing even though bucket is empty and in place correctly
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Hope this helped. Thanks for choosing FixYa.
Aug 22, 2011 | LG Dehumidifiers
Why is the red water full light on and not worrking?
Usually, when the red water full light glows, it means that the water collection bucket is full & needs to be removed and emptied. Once that's done and the bucket is reinstalled properly, the red light will go out and the unit will turn back ON.
Jul 07, 2011 | Daewoo DHC-400 Dehumidifier
RED BUCKET LIGHT FLASHES OFF & ON HUMIDITY SAYS 01 NOTHING HAPPENS
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 13, 2011 | Dehumidifiers
Kenmore dehumidifier # 54501.. Will not start..."01" comes up in the screen and the "full bucket" red light flashes on and off, but it is empty. put the bucket in and out many times but still will not...
According to this, a user was able to remedy the error by replacing the sensor assembly. Unfortunately, I have no idea how to do this, and I cannot direct you to a place to purchase a new part, so you may be better off getting it repaired at a local Sears retailer.
Aug 03, 2010 | Kenmore 54501 Dehumidifier
Keeps flashing bucket full and there is no water in the bucket.
water is not draining into the reservoir an thats why it keeps on blinking so clean out the drain assembly an treat with bleach ,,,,
May 24, 2010 | LG DH504E GoldStar Dehumidifier
Red light is flashing on my Zenith dehumidifier every 7 seconds or so. Bucket is empty. what should i do to get it running again?
take out bucket and locate bucket full switch, depress it, if unit works you will need to add shim to bucket to hold it in.
Dec 31, 2009 | Dehumidifiers
Ebac HD880 Dehumidifier Logo
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
Gil Shultz
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
