Question about Technics SL-1200MK5 Turntable
Turntables my two turntables have all of a sudden stopped working. i have tried changing both fuses on the plugs to see if that was the problem but they still are not working. The turntables i have are the SL-1210 M5G.
  • 1 more comment
  • swammyshay Dec 05, 2007
    switched voltage selecter now technics dont work
  • Anonymous Aug 30, 2008
    how to change fuse
  • djdonking Jan 22, 2009
    i have been messing round with my deck and i also turned the volt switch around and now it wont come on! i havent got a clue what i need to fix it or how to fix it? help would be appreciated
  • 515 Answers
Your power transformer blew. The fuses in these models don't offer much protection, when it comes to more serious power surges. And the only other thing that would be blown is the transformer - a common issue. You can purchase parts for this model HERE, however, I do not suggest replacing this part yourself, as it is a little tricky, and you may damage your unit ever more, if not done properly.
- DJ PRO AUDIO
www.DJPROLAB.com
Posted on Mar 21, 2008
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Apr 30, 2008
    As I stated earlier, the fuses don't protect from power surges. The fuses were installed AFTER the power transformer. So any surge will go directly to the transformer FIRST, then to the Fuses. The fuses are not meant to protect the transformer. They are meant to protect the fragile main circuit board only.
    There is nothing else on these units that control the power. So if you have no power, the issue is with the Transformer. Trust me on this one. I work on an average of 30 turntables a month - all Technics 1200 varieties.
    - DJ PRO AUDIO
    www.DJPROLAB.com
  • 3 Answers
1)I know it might sound silly, but try using different plug sockets, ie down stairs. This is to see if its a problem with sockets. Once had a dodgy power cord that kept one deck from turning on. 2) Check the the voltage is set correctly on both decks, by looking at the hole on the left side of the platter. My little brother messsed around with the turn switch and it blow the internal fuses years ago. If none of the above work it means the equipment could have had an electrical surge and knocked out the internal fuses. Can help you with that if needed. Let me know. Peace DJ Nyce
Posted on Jul 25, 2007
For both to have stopped it must surley be and external prob? ie power extention or something...thats very odd??
Posted on Jul 15, 2007
SOURCE:
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
Marantz DV4001 DVD player suddenly won't power up. Rental DVD stuck in player. Besides the lack of power issue - is there way to open the DVD player manually?
YES, UNPLUG, REMOVE SCREWS @ BACK & SIDES, CHANGE FUSE ON POWER BOARD,OR YOU CAN TRY & RELEASE THE TRAY BY WINDING THE COGS BACKWARDS. CHECK YOUR PLUG FUSE FIRST.
Oct 10, 2013 | Audio Players & Recorders
I put my Microwave on for 30 min and it suddenly stopped working, suggestions?
If there is no power at all to the display or the panel then it is failure of the board. But if there is power without heating, if the turntable/fan/light works, then it can be related to failure of relay, Magnetron, Waveguide or capacitor.
Jan 31, 2013 | GE JVM1650 1000 Watts Microwave Oven
My 1210 was working fine the other day, my daughter was playing around with it turning it on and off but nothing too harsh. I went to turn it on today and there is no power what so ever. How do I change...
Your turntable may be plugged in to a "switched" power outlet on your receiver/amplifier. If it is, your amplifier needs to be on for your turntable to get power.
Apr 26, 2011 | Technics SL-1210 Turntable
I have a Microwave model 721 63252300. It suddenly stopped heating. The other main components are working, fan, light, and turntable. Thoughts?
Hi! from what you have describe, it seem that your magnetron is not working that is why it is not heating. try to look for a busted fuse.
Sep 22, 2009 | Microwave Ovens
Advantium microwave won't stop.
If it runs when the door is open it's a bad interlock assembly
Aug 31, 2009 | GE Advantium SCA2000B Microwave Oven
Technics SL-1200MK5 Turntable Logo
412 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
