Question about Kenmore 43142 Front Load Washer
Kenmore 417.41042000 front load washer leak
Water dripping from drum shell seam at two bolt locations at the bottom. Sears parts shows a shell seal for $17 that wraps the entire inner dsrum assy. Is this the problem, or is it originating somewhere else and migrating to this spot to drip? I already have $100 into a new mallory/sole motor speed control & dont need to short out another one. Thanx! in advance.
  • Anonymous Jan 26, 2009
    I just developed a leak that I thought was at two bolt locations at the bottom, but upon inspection during fast spin cycle, I noticed water flying out higher up on the shell. I ordered the shell seal from sears.com today, will try to tear it apart tonight. Interestingly, I had to replace the speed control card a year or two ago as well. My model number is 417.4114200.
  • Anonymous Jan 27, 2009
    I tightened all of the shell bolts last night, ran a load and saw no leaks. I will be cancelling my order for a shell seal. In order to tighten the bolts, take the dryer off the top (or lid if side by side), and remove the front bottom panel.
Shell seal was replaced & problem solved, although it was a very labor intensive task
Posted on Jan 27, 2009
Can water be held in drum or under drum... my water is off but its still dripping underneath.. for 2 days now also can overloading cause this to happen?
The design of this washer has the tub (outer container) in two half's that clip/bolt together. It is likely that the seal that seals the two half's has failed. You need to confirm that this is the source of the leak. Others have reported as you the same condition and have confirmed that this seal will leak.
The red arrow points to part number 10 seal.
It you can confirm by observing the source of the leak that it is the seal the part is available and this can be repaired!! The repair is not for the faint of heart and requires lots of experience and finesse.
If you cannot confirm that the tub seal is leaking then check the front door seal. The front door seal is not as difficult to replace and there are many videos showing the replacement. Your observation that the leak continues is an indication that the residual water in the tub is slowly leaking. If the washer has frozen then it is possible that it might have been related to the leak. I expect that the load size is not the root cause.
Check you owners warrantee this leak may be covered by an extended manufactures warrantee.
You might live with the situation for a little while finding a tray to catch the water. Others have reported mold forming on the tub.
If you are not strong of heart to tackle DIY, but fat in wallet you may seek to get a repair estimate. Compare the repair cost with a replacement machine.
26039797-cmpppu1nchs2wy552ovfnv1h-5-0.jpg The following video makes the replacement seem so easy!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
Jan 05, 2016 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Is repair time and parts extensive for this type of repair? Kenmore Front Load Model# 110.45986401
Confirm that it is not the door seal. The door seal can easily be replaced and the parts are available.
You would expect that any water leaking around the door seal would migrate down to the lowest part of the tub leaving the appearance that the leak is where the two half's of the tub are joined by the retaining clips
Replacing the seal between the two tub half's is a different story as compared to the door seal. The tub seal is definitely do-able, but not for the faint of heart!!
If the leak is very very small I might wait until a major overall is require such as the tub seal/bearing. If I chose to wait I would monitor the situation.
Inspect the area at the hub of the pulley looking for streaks of rust.. If there is an indication that water is leaking past the basket tub seal than doing an over hall now may included front door seal, tub seal, bearing and basket seal replacement.
Dec 30, 2015 | Washing Machines
MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Oct 17, 2009 | Kenmore Washing Machines
Washer leaks water in the back of the washer but i cannot see any signs of the leak. this is a front load washer . model 970 ca0042 00,
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Oct 14, 2009 | Kenmore Washing Machines
Leak at bottom bolt of drum seal
the entire tub must be removed - the most expensive of all repairs labor-wise.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer leaks
It's not difficult to line up the boot around the door. The difficult part is taking out the tub (basket and plastic shell). Everything needs to be disconnected, and removed from the back, as well the tub is very heavy and best to do as a two person job.
If your washer is only 5 years old, it's kind of a 50/50. The cost (with labour) to fix the leak would come to approx $450 cdn.
Jan 30, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Self seal gasket for plastic drum
thats the main tub seal, youll need to remove the tub completly from the machine, split it and then reassemble after installing the new gasket and hope you didnt damage anything in theprocees. big bucks for the repair i bet, iim in NYC and id bet problalby 325-425, alott of labor involved!
Oct 30, 2008 | Frigidaire FTF530FS Front Load Washer
Leak
Ok Let us look at everything that can leak on the machine, get a good light and check the following.
Hoses on the back of the pump
The bellows, grey seal at door
The boot were it attachs to the tub
Look at the tub for water dripping off of center where the seam is
Aug 05, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water leaking from bottom of door during wash cycle
this will more likely be your door seal open the door pull your seal so u can see inside and feel around as u look u will more than likely find a hole the water looks like it comes from somewhere else but it will be from the hole in the door seal seen this with hundreds of washers m8
Aug 26, 2007 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
612 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
