Question about Panasonic Sa-bt228 / Sc-bt228 Home Theater System Blu-ray
F61 on scbt228 - Panasonic Sa-bt228 / Sc-bt228 Home Theater System Blu-ray
Panasonic f61
f61 on a panasonic usually means an amplifier problem. Depending on the model, probably have to have the amp pcb replaced.
Jul 01, 2013 | Audio Players & Recorders
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 Panasonic SA-AK240
am o combina muzicala marca panasonic modelul sa-ak240 si imi da o error f61,dupa ce o aprind la nici un minut imi da error f61 apoi se stinge.din ce cauza ma puteti ajuta??veri.nice78@yahoo.com astept un raspuns
Sep 08, 2010 | Audio Players & Recorders
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
F61 on dvd
audio amplifier IC damaged need to be replaced
Jul 23, 2009 | Panasonic DVD-F61 Multi-disc DVD Player
Error f61 on a panasonic SK-AK640 CD stereo system
when i turn the power on , it goes off in 3 sec after displaying "f61"
May 31, 2009 | Panasonic Audio Players & Recorders
Error code F61
Please describe your f61 error code problem:
Aug 09, 2008 | Audio Players & Recorders
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
Panasonic Sa-bt228 / Sc-bt228 Home Theater System Blu-ray Logo
16 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
