Question about HP DeskJet 5740 InkJet Photo Printer
My printer has a full black in cartridge, but the print is gray and blurry
  • skaretm Jan 25, 2009
    Tried it, but there is no "tools" or "maintenance" tab on the top. It has General, Sharing, Ports, Color Management, and About.
    Any other suggestions?
  • 258 Answers
Try going into Control Panel
--> Printers and Faxes
--> Right Click on the Printer ICON and select Properties
Look for a maintenance or tools Tab across the top and try Cleaning or Deep Cleaning
Posted on Jan 25, 2009
  • Peter Conway Jan 25, 2009
    Try Right Clicking and see if it's in Printing Preferences
Black ink cartridge full but will not print in black. Prints grey when colour selected
can u plz confirm is it now cartridge or old, & check is it black or gray cartridge. might be it is gray.
Dec 31, 2010 | Brother MFC 210C All-In-One InkJet Printer
How do I direct my Canon ip4300 Printer to no longer print from the normal black 5BGBK cartridge (empty) but to print from the 8BK (full)
You can't because CLI-8Bk ink cartridge is use only for photo printing.For text, document or gray scale printing the printer use PGI-5Bk.You need to replace your empty PGI-5Bk.
Oct 19, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Color printer full will only print black in my
You would nee to check you printing setting it migh be set to print only in gray mode
Sep 23, 2009 | Office Equipment & Supplies
Dell 922 won't print black ink... only uses color cartridge... I can't find selection to use black ink only. The checkbox for print black n white for color is grayed out... Cartridge levels show black ink...
Perhaps the printer does not recognize that a mono/black cartridge is installed. Remove the mono cartridge and check to see that tape is removed then re-seat firmly. Unplug the printer from wall power to reset. Then try again.
Aug 22, 2009 | Dell 922 All-In-One InkJet Printer
Printer cant print in black and white
This happend to me also and I finally found out that the printer uses collor cartidges for GRAY printing. The back cartridge is used for BLACK printing ONLY. So if the printer was short of one collor in my case it was magenta (red) the gray parts of BW prints started to be green!!! When I put new magenta cartridge to the printer gray was gray again...
Mar 03, 2009 | Canon MP610 Photo All-In-One Printer
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Print quality
Oh you are running out if ink i bet
Jan 25, 2009 | HP DeskJet 5740 InkJet Photo Printer
When I want to print using the photo or black ink cartridges, my printer uses the tricolour cartridge. If I take the tri colour cartridge out, the printer alerts that there is a cartridge missing and still...
If what you are trying to print is a black in white image then you cant print that when you dont have the other colors installed. The reason is because your image/photo has shades of gray, and for the printer to produce gray, it needs the other colors as well. It needs colors to get the light black or gray shades of the photo....
If however, you are trying to print text only, the printer should be using the black cartridge and not the other colors... I believe that there should be an option in the printers preferences to select black ink only... look for it under advance tab...
hope this helps
Sep 05, 2008 | HP Office Equipment & Supplies
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer problems,
i think the heads need cleaning click start ,click devices and printers, right click on the printer image, click troubleshoot and follow instructions.
May 07, 2017 | Canon BJC 8200 Photo InkJet Printer
HP DeskJet 5740 InkJet Photo Printer Logo
91 people viewed this question
Ben Johnson
