Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Computer does not recognize mY SEAGATE BARRACUDA 7200. 11 500 GB
I think that it is a problem with the usb port on the hard drive itself because when i commect my ipod in it works fine.
    Problem Solver:
  • 7 Answers
Does the drive work on another computer? Does it make clicking noises? If both answers are no then you propably have firmware issue. Those drives have a common firmware issue which can be fixed if you have the tools. I had this firmware bug in my Maxtor drive and I bought this kit to fix it
from Amazon. And since then I have fixed more than 20 Maxtor and Seagate drives with it.
Posted on Mar 13, 2015
  • 102 Answers
Try using your SEAGATE Hard Disk on another PC , if it works then you have one of these problems,
1. Your USB Port in your PC (Or Laptop) is broken and you have to get another one*
2. You have a software problem (Try reinstalling your OS or scan for viruses).
3. The USB Cable has a problem (get a new one).
(*) some technician can replace your USB port or fix it, or you can buy a "USB Hub"
Posted on Jan 25, 2009
My new Seagate Barracuda 7200 does not
Hi Simlei.
If its a modern, fairly new drive, it should have built-in firmware, without a need for extra drivers.
If you OS is old the OS itself may not be recognizing the drive's 'language', especially if the bus-width differs, ie 16/32/64bit.
As 1 TB is quite recent on SSD's, I guess its new.
My 1 TB Toshiba just plugs into USB and Win Explorer detects it as a storage drive.
Regards, Clive.
May 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
The hdd is not recognized by the pc, evrytime i plug in the hdd it ask me to formated
Are you using EXTERNAL HARD DRIVE, which means the hard drive is in a box, and you connect it to computer with USB cable? If so, do the following
1. Try to plug and unplug and plug USB cable at the port on computer. 2. While plugged in, try to shake the plug a little. 3. Try to plug the USB cable to USB port at the back of the PC case, not the port at the front 4. Check the usb cable, buy a new one, or borrow one (its cheap) 5. Still does work? bring it to Customer service, there must be an error on the box itself.
Mar 25, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How to transfer data from seagate barracuda 7200.7 ST380011A 80 GB hard drive to another hard drive after crash?
You need a usb cable to harddisk. than a computer running linux. connect hd by usb to linux and copy.
Jan 13, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer's hard disk seagate 40 Gb is damaged but it will show in bios set up . how can i recover my data back plz tell me.
The best way to recover your data if you cannot boot up your computer. Remove the hard disk and attach it to an USB hard drive adapter. Plug this adapter into a working computer's USB port and this computer should see this as an external storage device. You can then open the folders and files to backup/copy, provided the hard drive is not faulty.
Aug 12, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hi my Seagate Barracuda 7200.7 ST380011A 80 GB has crashed..and i want to recover photos in it, do you have any solution ?
the easiest way it to buy a usb external hard drive caddy, you then will be able just plug in to a usb port once you have installed the drive to the caddy which isn't hard to do.
Mar 19, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 EIDE 160 GB. Computer does not recogniz
If you plug it in and windows states that the device could not be recognized, try plugging it in in one of the USB ports in the back of your case, This worked for me.
If you just can't see your HD in my computer, try these following steps.
Go to:
Conrtol panel
Administrative tools
Computer management
Disc management
Now you should see see the drive in the schematic below, then right click on the drive and assign a new drive letter.
Restart, and all should be set.
If this does not work, have a look at the jumper settings on the drive itself. For this you must take the hard drive out of the case again.
Hope this works. Please rate this.
Best regards
Sep 28, 2009 | Seagate Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
671 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
