Question about Seville Classics MSC10166 Tower Fan
Seville classics 10127
Cleaning blades
Seville classic fan was cleaned and now it will not come on.
Dry out!!!!! Why would you get it wet? Anyway, check the reverse switch to make sure it's in the correct position.
Feb 24, 2015 | Seville Classics Dryers
Seville classics fan turns on and oscillates but does not blow air
Fan blades installed backwards? I assume the blades are rotating?
Aug 03, 2014 | Dryers
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
Where is the fuse located on the Seville Classic tower fan model 10199.
https://www.sevilleclassics.com/uploads/products/pdf_20120315132254_Tower%20Fan.pdf
Although the link is for a 10127 fan, page 2 will show you the fuse, which actually in the plug. Hope this helps....
May 11, 2014 | Dryers
The fan has power and will rotate, but no air is being blown out. any troubleshooting tips or is it a goner?
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
Sep 29, 2010 | Seville Classics MSC10166 Tower Fan
HOW DO YOU CLEAN THE INSIDE OF THE SMALL PERSONAL SEVILLE
Put it in the dishwasher, leave it in the sun for 2 days to dry out.
Apr 15, 2010 | Dryers
How do you clean it? It shoots out dust!!
You need to change the air filter, make sure you clean out the air filter chamber before installing a new one. it should be fine then, Good Luck
Feb 07, 2010 | Seville Classics MSC10166 Tower Fan
Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Jun 01, 2009 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Seville Classics MSC10166 Tower Fan Logo
57 people viewed this question
Top Seville Classics Dryers Experts
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
