Question about Microwave Ovens
Samsung microwave oven MU 4290W - Microwave Ovens
Mu accuwaave makes a short noise intermittenly while trying to heat
Is your microwave oven set to full power when the intermittent noise occurs?
If it's set to a lower power rating, then the noise you describe sounds perfectly normal.
At a lower power setting, the device which creates the heat or microwaves, called the magnetron, switches on and off intermittently so that the food etc. is not cooked too fast.
This is quite normal & you should only be concerned if the noise occurs while the microwave oven is set to full power.
In that case you will have to have it checked out to see what the cause is.
Best wishes,
Graemevm
Mar 24, 2011 | Whirlpool Accuwave Microwave Oven
All the electronics go and the light turns off when you shut the door but the microwave never heats-up. Samsung SMH9151
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 02, 2010 | Samsung SMH9151 Microwave Oven
Samsung microwave Model RE1320R 75AG500295
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
y
Apr 20, 2010 | Samsung MC5694 Microwave Oven
My samsung SMH7178std microwave doesn't heat anything up. it makes a buzzing sound after i set timer and press start.
heatman101
jgk
Feb 10, 2010 | Samsung SMH7178STD Microwave Oven
Convection starts ok, but quits after 10 minutes. It's 11 years old
Trying to calibrate mu sharp 32LE700UN. Settings are as follows:'
OPC is off, baklight at +14, contrast +30, brightness +2, color +2, Tone 0, sharpness 0, CMS Hue +12. Are there any settings I am missing or need to change to get the best picture? Also, color temp at middle and AV Mode at Standard.
Dec 16, 2009 | Sharp R-930AK Convection/Microwave Oven
Mocrowave clod
heatman101
9t
Jan 23, 2009 | Samsung MW1030WA Microwave Oven
Microwave operates but does not heat
The High Power Transformer (Magnetron) fuse is wrong. Replace it. It will work perfect... The fuse is always hidden in a plastic case fixed at the bottom of the microwave near the big capacitor... My email: neo@intnet.mu
Aug 19, 2007 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
