How do I remove a question asked in the wrong section
New to Fix ya asked my dishwasher question under washing mahines - woops. Can I remove it?
  • 1,824 Answers
You can click on Report Abuse and select it's in the wrong category:
how do I  remove a question asked in the wrong sec - 1_19_2013_8_32_40_am.png
Posted on Jan 19, 2013
  • Alan Ferguson Aug 16, 2013
    I did the same thing and want to remove, but the Report Abuse flag does not appear on my question page.
  • Janis
    Janis Aug 16, 2013
    Hi, try this:
Its a samsung vrt model number is WF330ANW/XAA 01
woops posted in comments section sorry about that.
Jan 12, 2018 | Samsung Washing Machines
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
How do i transfer pictures to a folder
just so ya know your asking computer question which i do not know the answer to under the home appliances catagory please repost it under computer section and if ya have a question about a refrigerator or dishwasher ask away
Jul 27, 2011 | Kitchen Ranges
Hotpoint dishwasher swd6o
all dishwashers don't heat the water themselves. the water supply should be tied into the hot water line under your kitchen sink.
Sep 18, 2009 | Dishwashers
Dishwasher does not pump water out at the end of it's cycle
First check that there isn't anything blocking the drain area inside the bottom of the dishwasher. Sometimes plastic wrap, a small Tupperware, etc. top gets sucked against the drain and blocks discharge. If nothing is there, (look really good, by getting out as much water as possible!!!). If nothing there, see if you have an "air-break" installed at the kitchen sink, this prevents backflow from the sink drain back into the dishwasher, check it by removing the decorative cover and see if it is clean and has no obstructions blocking water flow.
Another thing to check, is if you recently had a new disposal installed, it's possible that the dishwasher inlet was never "punched out" to allow for the dishwasher to drain thru the disposal. If none of those, continue with the investigation!
Check to see if some broken glass might have worked its' way into the drain area, beneath the drain discharge guard. You'll have to remove the cover, some are just clipped in place while others have a screw holding them in place.
If still nothing, it is possible that something has worked its' way all the way into the discharge pump section and you'll need to remove the dishwasher from under the counter to get at the pump section.
Normally when the dishwasher is in the pump out sequence, you can hear the pump motor and impeller spinning, if you can't, then proceed with removing the dishwasher and disconnect the power or shut off the breaker to it. It is quite possible that something has jammed the discharge impeller and is preventing pump out. Again, if you can hear the motor and impeller running, it could still have an obstruction. Bucket and towels will be needed to soak up all any water that you couldn't remove before pulling the dishwasher out from under the countertop.
If there is no obstruction in the discharge pump section and the discharge value (usually a simple rubber flap) is moving freely, then it could be the pump out solinoid (an electronic valve that opens the discharge port for pumping out water when the dishwasher is done washing and is signaled to drain. You should be able to cycle the dishwasher through a short cycle (wash & rinse) to see if everything is working OK. You'll need to reconnect the power, water inlet and discharge (drain) lines first to check this option.
Jul 28, 2009 | Stoves Dishwashers
Sig amount of water remains at the bottom after a wash
Another thing to check, is if you recently had a new disposal installed, it's possible that the dishwasher inlet was never "punched out" all the way to allow for the dishwasher to properly drain thru the disposal. If none of those, continue with the investigation!
Normally when the dishwasher is in the pump out sequence, you can hear the pump motor and impeller spinning. It is possible that you have a partial obstruction and will have to remove the pump housing to get at the problem
If there is no obstruction in the discharge pump section check the discharge value (usually a simple rubber flap) is moving freely and has nothing obstructing it.
You should be able to cycle the dishwasher through a short cycle (wash & rinse) to see if everything is working OK again.
Jul 28, 2009 | GE GSD5620DBB Dishwasher
Water won't drain
If there is no obstruction in the discharge pump section and the discharge value (usually a simple rubber flap) is moving freely, then it could be the pump out solinoid (an electronic valve that opens the discharge port for pumping out water when the dishwasher is done washing and is signaled to drain. You should be able to cycle the dishwasher through a short cycle (wash & rinse) to see if everything is working. You'll need to restore AC power and have the water line turned on for this. If you don't see or hear the valve open up when the wash cycle is over, then it could be this part that has failed.
Jul 07, 2009 | Electrolux Kenmore 24 in. Built-In...
Water does not go into dishwasher
first make sure the water is turned on to the unit(i know but i gotta check)if you'r sure you have water pressure to it.the float may have gotten stuck in the full position.this is located in the tub under a cover,that kinda looks like a small silo.remove the cover & make sure it is at the lower end of its movement.if this does'nt fix the problem i'll need a little more imfo.thanx for using fix-ya.please rate all replys
Nov 15, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Need to remove wash module
You should be able to hold the spray arm and unscrew the center section to remove the entire assembly. Be aware of any washers or other parts that need to be re-installed when putting it back on.
Jun 13, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
