Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Not detected by My Computer
The Maxtor drive shows up under "Disk drives" in the Device Manager and according to the status is working properly. However I cannot access the drive as it does not show up in My Computer. I have uninstalled and installed in device manager but it makes no difference. Habe also disabled/enabled but to no effect. Can anyone suggest a solution? Thank you
  • 14 more comments
  • Colin Starr Jul 14, 2007
    Thank you - it worked!
  • tomballbrown Nov 03, 2007
    my maxtor 3200 external isn't recognized in disk management either although the device is listed as working properly in the device manager section under hardware.I can uninstall and reinstall and try to update driver but says I have the most updated driver to date.Its been fine for about a year so far as well.When I unplug it and plug it back in it makes a new sound that is very much like a ringtone also.What gives...any ideas...Any help would be great!!!!!!!
  • sicabaca Nov 04, 2007
    maxtor 3200 shows error when i plug it in and says it may not work properly.
  • good lookin Nov 06, 2007
    MY Computer cannot see the drive it does show up in device manager, under properties, says that the device cannot start (code 10) Good lookin
  • Anonymous Nov 08, 2007
    i reformat my hard drive
    i accidentally reformat the hard drive
  • Anonymous Nov 19, 2007
    It will not show up in my computer....
  • Susannah Nov 20, 2007
    My external hard drive is plugged in, but it isn't showing up in My Computer.
    I've checked in Control Panel / Administration Tools / Computer Management / Disk Management - but it's not showing up anywhere!
    What do I do now?
    Susannah
  • Gwenlrin Nov 21, 2007
    The usb hd is marked Unreadable and my partitions cannot be accessed at all. The harddisk is not visible - and can not be formatted. Any other solutions?
  • m hustings Sep 17, 2008
    I have a maxtor onetouch 3 60GB mini and i have the same problem as described before, namely that although in device manager the drive is recognised and supposed to be working fine it does bo actually appear anywhere else so i cannot access it.
  • mattkube Oct 12, 2008
    i am having a similar issue with my maxtor 3200 hard drive. My computer froze one day, rebooted the computer and never fully rebooted. I unplugged my hard drive in case I would lose any data, rebooted the computer and plugged in the hard drive...the hard drive is not recognized now. Have I lost everything? What can be done?
  • arunakus Feb 13, 2009
    i don't see even my portable MAXTOR 250 GB hard disk in the diskmanagement.Any help please very urgent
  • simpora Feb 20, 2009
    I have a Maxtor external hard drive and it has always worked perfectly. I just tried to plug it into the usb and it does not show up as detected on either my desktop computer or lap top. Help!
  • edwinpingca Mar 02, 2009
    I have maxtor 3200 200gb, before it was working properly but suddenly the hard drive doesnt appear anymore in my computer. While it appears in disk management but need to be initialized, I try it by right clicking and select initialized disk but after the process, the status remained unchanged "Not initialized" and I cannot change either the drive letter assignment because the drive is unallocated, and no format option while doing right click on the drive.
  • jennmarie_22 Mar 19, 2009
    Maxtor external drive on recognized in My Computer. Cannot access files on hard drive. What can I do to retrive files?
  • frieda2009 Mar 22, 2009
    I have an external hard drive. it was working finr for abt 5 months. then one day half hour after i used it at work, i tried using on my notebook. it detected there was the hard drive and red light is flashing but it is not there in the my computer and neither can i get access to it. pls help i have lots of data on it which is very very important! pls help
    frieda
  • 432 Answers
Go into Control Panel go into 'Administrative Tools', double click 'Computer Management' click on 'Disk Management'. Do you see the hard drive?? Right click on the drive and select 'Format'. If this didn't help, write back and we'll find another way.
Posted on Jul 14, 2007
SOURCE:
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Windows vista does not see it
It should see it.
Try connecting it to a different computer, to see if the problem "follows" the Maxtor unit around.
Does it show up in "Device Manager" (under 'Disk Drives' and/or under 'USB devices') ???
Is it brand-new?
Is it "defective"?
Is it still under warranty?
Jan 23, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 200 gb external will not show up in my computer after numerous installs
For Vista you don't need any driver for this, it should recognize and install automatically.
Did you check the device manager to see if the disk is recognized in the device list?
Next step is to check the Disk Manager (right-click My Computer, select Manage and then select disk management), and see if the disk already has a partition and has been formatted. If not, then it will not show up in "My Computer" with a drive letter yet.
Some details on external hard disk troubleshooting might also help.
May 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
HDD unable to detect at My Computer
Well first I would pull the hard drive out of the case. I would then get a USB to IDE/SATA drive cable. I would connect the drive not being able to be detected to another computer via USB.
If it works the drive is still good but the data might be corrupt. If the data is corrupt I would be sure to get any stuff you can off of it and basically reformat and reload.
Mar 13, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
My slave hard disk is not showing in my computer
Is it formatted ? Does it have a drive letter associated to it? If not then either format it (right click on My computer -> click Manage -> click Disk Management. Now right click the drive if it is showing there and either create partitions and/or format it if it not already formatted.
If it's already formatted, and you just need to assign a drive letter, then in Disk Management, right click the drive and click Change Drive Letter and Paths and assign an unused drive letter, say Z.
Close Computer Management and open My Computer. The new drive should show up now.
HTH,
Deboo
Jan 05, 2009 | Seagate 250GB Maxtor DiamondMax Plus 21...
Maxtor 80gb hard disk not dtecting
You might want to try downloading this fix from Microsoft. http://support.microsoft.com/KB/908673, as your first line of attack.  The problem seems to be within your usb 2.0 hub on your computer.  See if this helps.
Thanks for posting.
Mark
Dec 01, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor personal storage 3200 200 GB hard-drive does not show up in my computer
The volume partition may be failing. So your machine can see the drive but you still cannot read or write to it. I would open it and extract the drive, to eliminate whether the drive and / or enclosure is at fault.
Oct 08, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard drive problem
just right click on my computer go to manage and then go to stogae and then select disk managment it will show the list of hard drive connceted select your drive according to the size. format it and it will show you in my computer. bye
Oct 01, 2007 | Gateway ONE GZ7108 All-in-One Desktop PC
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
829 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
