Question about Whirlpool AWG5122 Front Load Washer
Lights flashing on whirlpool awg5122 - Whirlpool AWG5122 Front Load Washer
3 Suggested Answers
  • 77 Answers
SOURCE: i have 3 flashing green lights on the front of
which lights are on?
Posted on Nov 04, 2010
  • 6277 Answers
SOURCE: awg5122 not draining light over
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 05, 2011
Hi, my AWG5122/S machine is not taking the softener from the drawer on any cycle, any ideas why ?
Fabric softener has a tendency to slowly clog hoses by building up on the inside of the line. This is even more prevalent if you do a lot of Cold Water washing, since hot water will help to break up the residue. Check the tube that leads from the drawer for clogs.
Mar 06, 2015 | Whirlpool AWG5122 Front Load Washer
Awg5122 not draining light over 1h flashing tried to drain door locked and three lights flashed 1h 3h 5h.
John C
May 05, 2011 | Whirlpool AWG5122 Front Load Washer
Very noisy on spin
Hi.
Have a look at the drum bearing, that is the most common cause for noise on the spin part of the cycle.
Regards.
Ginko.
Feb 24, 2011 | Whirlpool AWG5122 Front Load Washer
My machine will not spin dry and empty the water after a wash, the lights will just blink and the machine will stop.
My machine won't spin or drain and just goes on and on for hours not taking notice of the cycle I put it on, can anyone help?
Jan 03, 2011 | Whirlpool AWG5122 Front Load Washer
My Whirlpool AWG5122 washing machine keeps overfilling, it seems to take in water to the point of overflowing, I have to turn the water off at the mains in order for it to stop taking water in.
sometimes if the door switch of that machine is not working so there is no auto stop of filling water. or the pressure switch may be not function well.
Dec 09, 2010 | Whirlpool AWG5122 Front Load Washer
I cannot get my AWG5122 washing machine to go onto the spin cycle
u will need a sevice manual appliancerepairplanet.vstore.ca
Dec 01, 2010 | Whirlpool AWG5122 Front Load Washer
The washin machine stopped mid-wash, the on button and timer button are now flashing but the machine is unresponsive
Unplug the machine from main power outlet and wait for 10 minutes then reconnect and recheck.If still the same problem then check the power to the motor with the meter.If the motor has power then its the timer control short or the faulty control panel board. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Whirlpool AWG5122 Front Load Washer
I require a user manual for a Whirlpool AWG5122 5kg 1200 spin washing machine
if you go to the whirlpool web site under support you should be able to download one.
Apr 07, 2010 | Washing Machines
Whirlpool AWG5122 Front Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
