Question about Maytag MHWE400WW Front Load Washer
Instructions to replace / repair the drive motor on the MHWE400WW01
Code F25 comes up (not all the time) and the drum locks, not all the time
F25 code on 3000 series maytag washer
Google search brought up:-
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
A serious and difficult fault to repair. Call a technician.
Nov 13, 2016 | Maytag Washing Machines
F25 error on maytag front load washer
F25 -
If the control is unable to properly detect motor speed, the washer shuts
down. If a failure occurs during high-speed spin, the door unlocks after
3 minutes
Possible Causes/Procedure
Verify the shipping system including shipping bolts, spacers and the
power cord are removed.
Unplug washer or disconnect power.
Check the drive motor tachometer resistance.It should be
approx. 115
? between motor connections
Check wire harness connections between the drive motor and the
Motor Control Unit (MCU), and between the MCU and the Central
Control Unit (CCU).
Plug in washer or reconnect power.
Check the MCU by looking for operations of the drive motor.
Check the drive motor for powered rotations.
unfortunately if your not familiar with the workings of the motor control and drive motor this is a tough thing to diagnose. its an issue between the motor # 13 and the motor control board # 1 on this diagram.
check the connections on the plugs, disconnect and reconnect them. in most cases it a bad motor control board.
Aug 09, 2016 | Maytag Washing Machines
F25 error code whirlpool washer did every thing I've found on the web even spent 300 on a control board and service tech still gives erro
im not sure why you replaced the mcu when an error code 25 is a rpm sensor loss , this is the sensor that tells the mcu that the drum is rotating and if so how fast , its been my experience if your getting this code then you either have an agitator blockage or a bad drive motor /sensor, happens most times due to water leak from front gasket worn down
Nov 12, 2015 | Whirlpool Washing Machines
Front loader maytag stop in middle cycle give error F25
Remove your service panel and look for your tech sheet inside a jacket in the inside of the service panel. An F-25 is usually a broken wire between the main control and the motor control.
Oct 09, 2011 | Washing Machines
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite F25?>
F25 = DRIVE MOTOR TACHOMETER ERROR
mostly likely need to replace speed control board
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
F25 error code
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Dec 18, 2007 | Washing Machines
Maytag MHWE400WW Front Load Washer Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
