Question about Sorel Manawan Slippers for Men
My slippers stink
My slippers have a horrible odor and I'm not sure if they can be washed. I need some advise about washing these slippers without damaging the leather.
KITCHENAID W10311123B STINKS
use the following product. God bless you
Affresh
HE Washer Cleaner - Recommended by Maytag and Whirlpool
Odor Remover and Smell Blocker .Oxigenated cleaning action lifts away the Stinky,smell odors in your HE washing Machine.
Jul 29, 2013 | Washing Machines
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Hoover wind tunnel can the dirt cup be washed it smells horrible and I am moving to new house and dont want to stink up the house with this vacuum I hate to go out and biuy a new one as this one is on
yes you can wash the dirt container in worm soapy water,rinse off and make sure it's absolutely dry before you use it again.this link is for the manual if you need it. good luk in your new home.***
http://hoover.com/file/570/
Sep 21, 2012 | Hoover WindTunnel Rewind T-Series UH70120...
It has a horrible odor. Also the little door on the left bottom front of the machine holds water. How do you keep the water (stinking) from standing in that area?
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
If the standing water is your fabric softener you'll have to clean it out to unstop it so it will drain.
Here's a DIAGRAM which may help with the cleaning.
Mar 12, 2011 | LG WM2233H Front Load Stacked Washer /...
Well, I wear my men's UGG ascot slippers a lot. I do not wear socks with them when I do wear the shoes. After I wear them, I spray the UGG odor spray in the slippers to prevent lingering odor. However,...
The problem is the heat produced in the shoes. Since they are so warm many people's feet sweat in them making them smell, and the fur makes the smell stay. One suggestions would be to obviously wear socks, that's what I do with my uggs. If you would rather not wear socks then you can try washing them, but you can only do it by hand because the washer may ruin them. Be careful tho because they are easily ripped when wet. If that doesn't help enough then get odor eaters for shoes and use them when you aren't wearing them. If possible many people have started to replace the inserts in their uggs. Click here to see a website that sells these inserts and click here for a website that sells odor eaters.
Feb 16, 2011 | UGG Australia Ascot Slipper Shoes
My washer smells horrible. The clothes after being washed smell horrible. I have left the door open. I have run bleach thru there 2 or 3 times in a row...didn't help. Have also run baking soda thru...
Despite washers remain with some residual water in the pump and wet components it should no be so critical as you are indicating especially if you cleaned it as you stated. You are not describing the smell but try to isolate the source, like the washer drainage point (odors coming from sewage), behind the washer, and inside or under the washer where the mechanical components are. It wouldn't be surprising to find a dead rat, lizard or pests in there. Sometimes even wet laundry falling behind the appliances stinks strongly. Be safe moving and reaching on difficult places. Good luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stinks
do the clothes stink too? or just the washer? if you have a crawl space check the washer drain it could be draining under the house...and vapors coming up through line......
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Bad odor
Go to LOWES and talk to the people in the appliance section.
They have a tablet that you need to run through your washer. I have to run the tablet every 6 months to avoid the odor.
Aug 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Neptune t.l. washer has a horrible odor that we have not been able to fix, either with bleach & vinegar solution nor with Electrasol lemon scent dishwashing powder, as has been suggested to us. This...
if you use liquid detergent for a long period this will cause a nasty smell and it leaves a horrid slime in pipework etc. if so, put on a boil wash and change to powder.
also, make sure there is a water barrier between the washer drain pipe and your house drains
Jul 11, 2008 | Maytag Washing Machines
Sorel Manawan Slippers for Men Logo
37 people viewed this question
Top Sorel Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Sorel Clothing Accessory Expert? Answer questions, earn points and help others
