Question about Hobart 120/240V SR24H Undercounter Hot Water Sanitizing Dishwasher with Detergent Pump
Wheres the soap adjustment hobart sr24h dishwasher
Need to increase amont of soap
3 Suggested Answers
  • 110 Answers
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Posted on Jan 11, 2010
  • 49 Answers
SOURCE: We have a hobart sr24h dishwasher which is leaking
hobartcorp.com under service tab click parts then smart parts system tab
Posted on Jan 29, 2010
Hobart sr24h; It is doing a double cycle; runs a compleat wash and rince cycle stops then 30 sec later start over so our normal 3 min clean now takes 7 min to fully stop operating. What could be the cause...
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Sep 17, 2011 | Hobart SR24-H Built-in Dishwasher
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Sep 19, 2010 | Hobart SR24-H Built-in Dishwasher
Hobart LXIH dishwasher
You can add a small amount commercial dish soap to the wash chamber before pressing the wash button.
Apr 02, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Sr24h dishwasher will not heat water, we have 110 volts to contacts but they will not close in cycle to turn on heater?
if you have voltage to bstr. contactor coil and contactor is not pulling in the coil must be bad on the contactor. try pushing in thecont. manually to see it is not bound up mechcanically, if you can do that replace bstr cont. because the coil is open. dont forget to vote, monomoy
Apr 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 120/240V SR24H Undercounter Hot Water Sanitizing Dishwasher with Detergent Pump Logo
66 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
