Question about JVC Kdr330
Adjusting speaker balance procedure - JVC Kdr330
How do I adjust the fade on the stereo of my 1996 Toyota Camry DX V6? it says "PULL FADE" underneath the BASS and TREB, but those nobs only effect the Bass and Treble.
Jim Norton Toyota of Tulsa, Oklahoma: 2012 Camry Adjust ...
? 0:54
https://www.youtube.com/watch?v=ghwosvmNxkk
Feb 8, 2012 - Uploaded by Jim Norton Toyota
Jim Norton Toyota of Tulsa, Oklahoma: 2012 Camry AdjustSound Qualities ... Toyota Tacoma Stereo Install with Bluetooth - 2005 to 2011 ...Missing: 1996
Stereo not balanced in 2015 Camry XSE - Toyota Nation Forum ...
www.toyotanation.com > ... > 7th Generation (2012+)
Apr 14, 2015 - 15 posts - ‎11 authors
I noticed that I can hardly hear my rear speakers in my 2015 Camry XSE. I have adjusted the fade control from the center position to the rear position. ... dash speaker on the driver's side, regardless of how I adjust the sound. DIY - How to fix a flakey volume control in a 2001 ...
Sep 25, 2012
DIY: 1996 Camry Power Antenna Replacement Procedure
Jan 18, 2009
AUDIO: What does ASL stands for while we adjust the ...
Jan 20, 2008
no sound from rear speakers
Mar 18, 2007
More results from www.toyotanation.com
Jan 15, 2016 | Car Audio & Video
Left front main speaker level drops after being on for a few hours
Volume Potensiometer may need dismantle and clean with special solvent
Jul 05, 2008 | Yamaha RX-V2700 Receiver
Both speakers on the left side has quit working
Try adjusting the balance or fade, it will be balance for left to right speakers to be adjusted, it may be as simple as this.
Apr 17, 2011 | 2004 Nissan Sentra
How to connect subwoofer
This manual discusses it somewhat.
http://service.us.panasonic.com/OPERMANPDF/SAAX730.PDF
Basically, feed the self-powered (active) subwoofer from the Subwoofer Out. There does not seem to be a way to adjust the subwoofer output to match the rest of the speakers because the sub out is muted during the adjustment procedure.
Another way would be to refer to page 15. The note at the bottom right suggests your subwoofer might accept full range speaker level inputs. Refer to the manual for your sub. I believe they mis-printed it and meant "active" subwoofer, as simply wiring a passive (unpowered) sub across the front speaker outputs might cause some amplifier overload issues and you would have no way of balancing it anyway.
Jan 17, 2011 | Technics SA-AX530 Receiver
How do I adjust the balance of the speakers? One
press setup on front. press speaker level control. use left and rt up and down buttons to select speaker and set levels. hit return to go back of setup to get out.
Mar 17, 2010 | Onkyo TX-SR504 Receiver
Adjusting front and speakers
Push the menu/sel button, select bal/fad. Pioneers use the same adjustment for balance and fade. push side to side for balance, up and down for adjusting front to rear
Aug 18, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Speaker left/right balance control
This Aiwa audio system has no balance control as its already balanced.
May 19, 2009 | Aiwa NSX-AJ20 CD Shelf System
Acer speakers desktop
***For Windows XP***
  • Click on start > Control Panel > Sounds and Devices
  • The Window Below will appear :
  • Click on the Advance button and the volume options will appear
  • Adjust the balance on the master volume (Just Drag arrow to the middle)
***For Windows Vista***
  • Click on Start> Control Panel>Sound
  • Click / Highlight the speaker then click on Properties
  • Click on Levels tab
  • Click on Balance
  • Adjust Balance
Nov 03, 2008 | Acer Aspire (AST180-US340B) PC Desktop
Only one speaker is working
i also have the same problem. in the begining both of the speakers were working now it's only one. it's not the balance setting either, i think i either blew something, but both of the speakers work when i switched the wires.
Apr 15, 2008 | Nakamichi SoundSpace 8 System
JVC Kdr330 Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
