Question about Kenmore 22422 Top Load Washer
Washer will not drain ALL the water out
My kenmore model 110-82380110 pumps some of the water out but not all. Could this be the pump or possibly water level switch
It was the coil in the wigwag assembly. The washer was not spinning causing it not to pump out all the water
Posted on Jan 29, 2009
Washer stuck in drain and spin mode
Hello. I need the model number to help you accurately. When the unit drains, can you verify water *is* actually being pumped out? This is important because no washer will spin if it can't pump all the water out--modern electronic washers have to balance the load and water is an unknown, shifting quantity. I need the model number to assist you in initiating the diagnostic mode and explaining the possible error code(s) you might be getting. I hope I helped you!
Sep 15, 2015 | Kenmore Washing Machines
My kenmore washer model number 110. 92573210 washer seems fine it just will not drain, is this the water pump?
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Kenmore 22422 Top Load Washer
I have a kenmore front loader recently it has decided to stop spinning and retain water. Help?
Regardless of model, this is probably a drain pump problem. With many Kenmore washers, there is a pump trap that can become plugged. Remove the washer's bottom front panel, if there is a white drain pump casing, turn out the pump trap counter-clockwise, making sure to have a bucket to catch the water. Check and clean the trap, and try to spin the pump impeller, if the pump impeller is stuck, something may actually be stuck in the impeller. If the impeller feels wobbly, you will want to just replace the drain pump entirely. Depending on the model, there may just be a hose connecting directly to the pump, with no trap available, just pull the hose off and check for an item plugging the pump. With any model, there will be WATER that will POUR out. Be prepared.
Mar 17, 2011 | Kenmore Washing Machines
Doesn't drain water and spin
It sounds like your drain pump is either clogged or bad. Bail out as much water as you can with a cup and then check the pump. There will probably be something in the pump stopping the impellor blades. There will also be alot of water so make sure you have towels and/or a bucket when you take the pump off.
Jul 06, 2010 | Kenmore Washing Machines
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Pump on kenmore elite not pumping water to drain
possible pump impeller may be loose on motor shaft also be sure tank to pump line is clear and pump to drain is clear
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer - wont drain and loud clicking sound from bottom
Yes...sounds like you may have something lodged in the drain pump impeller. The following link explains how to check the drain pump on this washer for obstructions:
It does not take much to damage the drain pump on this washer. If something has been lodged in the pump for any significant period of time, the pump may be damaged and required replacement. The may still run, but may not be pumping water as it should. You may experience an error code as well. On HE3 models, the error code is "F02" or "SUD". On HE5 models, I believe it is an "F21" error. Replacement pumps can be ordered on line at
If you find that you need to replace your pump, I have this additonal link, that provides step-by-step instructions:
Please read the note at the bottom of the link, as it IS possible for a pump to still run and not pump water. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 16, 2008 | Washing Machines
Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
Aug 15, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washer doesn't drain or spin
remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Jun 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 washer won't drain
Check first drain line or water pump to see if they are clogged.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump.
Jan 14, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
110 people viewed this question
Sal De
 Brian Main
Brian Main
