Question about Emerson Smartset Clock Radio
Emerson Smartset CK1862 does not auto set the time
I have tried unplugging it, replugging it, using it with and without the battery and replacing the battery, all to no avail. It always goes to 1/1/05 12:00 when plugging it back in. They want me to return it and send them $9.00 )plus shipping) to fix or replace it (half what I paid for it...I could just go get get another one...but what would I use in the mea time while they are "repairing" it?)
    President:
  • 814 Answers
In this case, it is probably better to buy a new Clock/Radio. You should also try to figure out what caused the problem with the broken Clock/Radio. This will help you prevent it from happening to the new Clock/Radio. You probably need a surge protector. The surge protectors will help prevent the Clock/Radio for being damaged by transient voltage surges that happen during storms and power outages. Sorry this answer is so late in coming to you. Thank you for using FixYa and have a nice day.
Posted on Jun 13, 2009
I have had my radio for many years but when I wanted to put it in another room it displays a half "L" on the display when I plug it in. Do I have to replace the battery when I'm using an...
Hello
You haven't specified nothing about your Emerson Smartset Clock Radio. Nothing is there about its model number. Yet I posts this solution before you assuming that yours' is a CKS3528 Emerson Clock radio.
There is a long life lithium battery installed in this clock radio when you buy it.
This battery can maintain the time and alarm settings for 3 to 5 years, or even
longer, so there is no need to pay for a new 9-volt battery every 6 months, as
is recommended in other clock radios with normal battery back up.
But if this lithium battery has gone down [ in terms of voltage]; the display 'L" will be there. It means that, it is time to replace this backup battery. It will be of disc type, usually used as bios setting storage, used in computers. OK.
May 13, 2011 | Emerson Smartset Clock Radio
Clock radio doesn't auto reset for daylight savings
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 06, 2009 | Emerson Smartset Clock Radio
Time change
Snooze doesn't work anymore
1.You will need to reset the microprocessor of the Clock/Radio. To do this you must unplug the Clock/Radio and take out the internal battery. You must let the Clock/Radio set unplugged and with out the battery for at lease 1 hour. Then replace the battery and plug in the Clock/Radio and see if the functions return to normal.If not try replacing the internal battery (CR2430) and leaving the Clock/Radio unplugged for a few hours. Then put in the new battery and Plug in the Clock/Radio and see if the functions return to normal. If not you may have other problems with the microprocessor. You can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. 2.http://www.emersonradio.com/dst.htm Copy this web link and paste it into the address bar of your browser. This will take you to the Emerson customer support web page. This page has the procedure for setting the day light saving feature in your Clock/Radio. I hope this information helps you with your problems.
Mar 13, 2009 | Emerson Smartset Clock Radio
I have an Emerson Smartset Clock Radio (CKS1862) and it doesn't
This Clock/Radio has had a problem with component failure. Since Emerson doe not support out of warranty repairs, you will not be able to get it repaired. Due to the low production cost of these short production run products, parts and service information are usually available to the manufacturer and service centers only. This mean that there is no parts and service information for independent repair shops. Even if you could get it repaired it would cost more than purchasing a new Clock/Radio. Thank you for using FixYa and have a nice day.
Jan 25, 2009 | Emerson Smartset Clock Radio
After 2 years Smartset presents problems
You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Jan 10, 2009 | Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Daylight Savings Times Changed
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Oct 29, 2007 | Emerson Smartset Clock Radio
Emerson Smartset Clock Radio Logo
133 people viewed this question
Top Emerson Audio Players & Recorders Experts
Blake
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
