Question about HP OfficeJet 6210 All-In-One InkJet Printer
Error: 0x07a74dd61959:lib-barracu I cannot get my printer to work. I have tried changing the cartridge and this has resulted in all the lights flashing and this message being displayed: Error: 0x07a74dd61959:lib-barracu . I have tried turning the printer off/disconnecting it for 5 minutes, but the same result!
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Posted on Nov 07, 2007
    Sergeant:
  • 274 Answers
I'd try un-installing printer, turn computer off (hard boot), and then re-installing. S\Could be a corrupted file but not sure.
Posted on Jul 15, 2007
SOURCE:
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
My Canon MX310 has an error code U051. I have tried 3 solutions on fixya and they did not work. One solution I get to this step and my printer will not show a steady alarm light.\r\nthe step that won't...
Error Message: Check Ink U051
This message appears when the cartridge not installed, not properly installed, or non supported cartridge is installed.
As a result the printer cannot recognized the installed cartridge.
Remedial action:
* Reinstall the cartridge properly
* Ensure that you installed supported cartridge only
* Replace the cartridge
Nov 18, 2010 | Canon PIXMA MX310 All-In-One Printer
I had my ink cartridge refilled, and now the
just clean the printhead contacts
if you see no result
you must change the cartridge
Apr 02, 2010 | HP DeskJet F4280 All In One Printer InkJet
New Cartrdige detection problem
I can't think of anything other than the obvious which is probably not of any use. Please make sure that you have the correct cartridge and that you have removed any tape or covering from the cartridge. Try turning the printer off and on after you put in the new cartridge. These are pretty simple but there are all I can think of. Good luck!
Mar 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Error Light
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Jun 14, 2008 | IBM Infoprint 1116 Laser Printer
Print has quit working at all
Please send to me your email address and i well send to you the error status or print the even log to see the even code number if possible
Apr 11, 2008 | HP LaserJet 2550L Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
1,748 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
