Surround Sound My boyfriend has just bought LG Surround Sound and only gets the sound through the 3 speakers near the Tv and not the 2 behind him, unless he has a DVD in the player? Please help Thank you Carol
    President:
  • 948 Answers
That's normal Carol. Television shows don't use the rear speakers very much.
Posted on Jan 27, 2009
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
Just bought lg ht44s home cinema to go with my lg tv connected hdmi lead can get radio and dvd surrond sound but not through my tv
Try going into menu-sound and enabling external speakers. I am not sure if this option is available. How is tv connected to your surround sound receiver? If it is component cable, try plugging them into the back of your surround sound receiver where the tv input is labeled. Then turn on your receiver and select tv from the mode button.
Apr 03, 2011 | LG Televison & Video
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Trying to get surround sound speakers to work with TV
They come with 3 x 3.5mm stereo to 2 x RCA phono cables, so are obviously meant for plugging in to the back of a PC with 6ch output.
BTW - they're ****.
I should've known for £29....
Jan 06, 2009 | Audio Players & Recorders
Lg 47 inch tv sound
We had the same problem of pathetic sound quality and volume with a sony brava. Thats just the way they make tv's these days because most people buy a surround sound system as well. We bought logitec computer surround sound speakers for about $140 and plugged into the ear jack, problem solved, we have heaps of volume and stacks of bass.
Dec 21, 2008 | LG 47LC7DF 47 in. LCD HDTV
Help With My Rear Speakers
Just clicked on sound effect on the lg tv remote it was set to 2.1 changed to 5.1 and the system came alive!!
Oct 07, 2008 | LG LHT854 Theater System
Set up the Panasonic SC-PT450 and followed all the various instructions. Am using the surround sound in conjunction with a Panasonic TV bought at same time (50" plasma) but can't seem to get sound out...
Are you sure you're using a source material that is surround sound? Most TV broadcasts are still only stereo.
Also with surround programmes, the rear speakers are only used for the surround effect so will only make sound when the sound source is supposed to be behind you.
Jun 25, 2008 | Panasonic Televison & Video
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
May 23, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
146 people viewed this question
 Grubhead
Grubhead
