Question about Philips Magnavox 42MF521D/37 Television
How do I tell if my tv is analog
I have two tvs. I have Time Warner cable. However, I am interested in ditching cable service and have the new digital tv WITHOUT buying a new tv.  How do i tell if my current televisions only need a converter box - or do they even need a converter box - maybe all they need is an antennae.  Can you tell me how I figure out what my current televisions support? THanks. Dru
  • dru_michaels Jan 25, 2009
    lone99star
    Thanks for the tip - meanwhile i have identified my two models and based on the antennaweb.org site i dont think either qualifies.
    I have a pansonic (not a phillips) CT 27D108 June 2000
    and a Sanyo DS27780 - i dont think it qualifies either.  thanks though
  • Anonymous Feb 08, 2009
    I have a Sanyo model DS27880. Is it analog?
  • 4,234 Answers
Dru:
Thanks for using Fixya. In order to clear up some confusion, let me explain the new digital standard.
As you have found, both of your sets will require the converter box. Boths sets have "Digital" tuners but are expecting Analog signals to be received. This means that the tuning is done using a digital method. The new digital standard (ATSC) broadcasts a digital signal that is broken down internally into the picture and sound. The new ATSC tuners are also digital but expect a digital not analog signal. Please note that if a satelite signal is used the older analog (NTSC) tuners will continue to work as usual. The ONLY change is for over air signals which are received using rabbit ears or a rooftop antenna.
Hope this helps,
Dan
Posted on Jan 26, 2009
  • 362 Answers
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Posted on Jan 25, 2009
  • Jason Morris Jan 25, 2009
    Hi Dru,
    Thanks for the reply, I am attaching another link to the governments Digital Conversion Coupon website, There is a waiting list now but as coupons expire more are issued. these coupons are for $40 dollars off the purchase price of a digital converter box, you should be able to get two.
    https://www.dtv2009.gov/
    I hope this helps.
    I wanted to take a minute to ask about the rating you gave for my solution, the ratings are confusing and can cause harm if not used correctly. You rated Thanks for Trying, that is actually a negative for me, it knocked my rating down almost a full point.
    If you would like to change the rating to at least Helpful it would be greatly appreciated,
    Lone99star
Is the TV Tuner in the 8806 analog only? It cant be used for OTA DTV?
GPX KCL8806DT television receiver has only an analog broadcast tuner to receive digital from Time Warner you will require a converter box.
Feb 17, 2015 | GPX KCL8806DT 7 in. Portable Television
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
My Vizio LCD HDTV isn't pickup up all of the cable channels, but my other older TVs are?
Did you retry a working TV again on the same input, as it looks like a case of loose contacts in the RC Jack, cable or connectors or some strands of the cable touching the ground. Then check whether your Vizio TV supports the system/format of the cable. If your cable is licensed to be used only with the other TVs, like sensing the identity of the PC used, it could also be a problem
Aug 22, 2012 | Televison & Video
Got the digital set up box from Time Warner Cable but they did not include hook-up instructions.
If you have an HDTV, you can hookup HDMI cable from set-top-box to the HDTV's HDMI input and select that input on the TV using your remote. If you have analog TV, you can hookup using RCA cables (yellow to yellow, white to white). You could also call Time-Warner for assistance.
May 16, 2011 | Televison & Video
Just bought a LG 32 LH20.I tried just screwing the cord that was hooked up to my other tv from my cable box into the new tv but it just says no signal.I have time warner cable with Dvr if that makes any...
You need to do a first time set up. The TV has to find what channels you have. You need to set the Tv to cable as your input and then auto scan for both analog and digital channels.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
TVGOS (TV Guide on Screen) stopped working on Time Warner.
split your input cable line and connect one end to your digital input and the other to your
analog or air input.
Jun 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Apex tv 2024
As long as the New Cable boxes have an analog output they will work fine.
Dec 27, 2007 | Apex Digital AT2002S 20" TV
Philips Magnavox 42MF521D/37 Television Logo
241 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
