Toshiba satellite PRO A Laptop
I have a problem with my Toshiba Laptop boot up.
It powers up but then turns itself off and then on again.
Iam running XP so I need some advice on how to sort this problem out.
  • llantrip May 11, 2010
    my suggestion would be to take out the battery completely and boot it up and see what occurs. If it still acts this way, I would say you have a virus/trojan horse that is interfering with start up
    Problem Solver:
  • 16 Answers
Your laptop may be infected by a virus or trojan.
I suggest you take the laptop to a qualified technician who will do the following:
1: Remove the hard disk
2: Attach the hard disk to another computer system as a SLAVE DRIVE
3: Scan the laptop hard drive for trojans,malware/viruses.
4: After scanning and cleaning, re-install the hard disk in the laptop.
That should get you going again! Please install an antivirus program afterwards to avoid the same happening again.
Posted on Jan 29, 2009
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
Toshiba support
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
My toshiba satellite laptop keyboard just quit and won't work, totally frozen and nothing appears as i type. pls help toshiba satellite laptop A215-S5837, windows 7, vista
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
May 12, 2011 | Toshiba Satellite A215-S5837 Notebook
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
My toshiba satellite pro 6100 will not turn on. The battery light and power light turns green but it will not turn on.
The problem could be your display. Use the VGA port on the side of your laptop to connect it to a computer monitor, this will let you know if your system is posting or not. (If you see the Boot Screen it is posting).
May 19, 2010 | Toshiba Satellite Pro 6100 Notebook
My toshiba satellite l300-1aq laptop is freezing within minutes of start up? I am running Windows Vista. How can I root cause the issue?
When you power up, turn the notebook so you can see if the cooling fan is running.
It sounds like the self protect shut down from over heating.
Feb 01, 2010 | Toshiba Satellite Pro L300 Notebook
No power to Toshiba A60
Make sure the laptop is off, pull the battery, and just power it up with the AC adapter. Once you get it going, head over to the control panel, and check the settings in power management. It could be that the settings are wrong and it will not let you start it up with the battery installed.
May 04, 2009 | Toshiba Satellite A60 Notebook
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Feb 18, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios...|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
Toshiba m200 iam relese the vista &install the xp
you have to make a clean install and not upgrade,boot your pc from the xp cd installer.make sure that your XP installer cd is not damage, try it on another pc and see if it works
Oct 14, 2008 | Toshiba Satellite A135-S4527 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
you have to use a standard windows start up disk with cd rom support like win 98 works well so the computer will recognize a older version then insert it and boot the computer with the operating system that u want to install but be advised if you have a warranty on the machine you will void the waranty i found out the hard way i had xp on my toshiba laptop and i put windows me on it couple of months later i had a cd rom issue and sent it to the manufacture and found out that the waranty was voided because i put a different operating system on the machine
Aug 14, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
