Question about Eagle's Camp Family Voyager Tent
Where can I purchase replacement poles?
During a bad storm the poles buckled and I need to replace them. Do you have any information as to where I can order them?
Cabela's may be able to special order them.
Posted on Mar 07, 2013
Where can I get tent pole repair for Royal Tokyo 8 tent?
Bend them back into place or contact the company for replacement.
Aug 27, 2015 | Royal Tokyo 8 Tent 2012
TV Will not power on
HAVE YOU CHECKED PLUG AND INTERNAL FUSES
May 28, 2015 | Televison & Video
Mitsubishi LT-20
Transformers are safety parts and should only be replaced with types approved by the makers of the device. Contact Mitsubishi for information on where you can get a replacement.
Remember inproper replacement could result in fire and death.
Jan 19, 2014 | Audio Players & Recorders
How to set up a spalding uv Tex 5 tent
First set the 3 eleven piece poles with 2 crossed across the tent and one across the front portion. Feed them thru the channels and buckles. Then put the pin hooks into the bottom of the poles. You will need to arc the poles to get the pins into the end of the pole. Next put the poles that are smaller into the channels and buckles for the two vestibules. Again put the pin hooks into the same pole ends as the back crossed one.
Stake the tent to the ground by driving the stakes thru the pin rings starting at the 6 corners of the tent. Pull front of vestibule taut and secure in place by driving stakes thru webbing loops at base.
Install the rainfly by draping it over the top of the tent. Hook each of the 8 S hooks onto the provided loops. Secure the rainfly to the poles by wrapping the velcro straps around the poles underneath the rainfly.
These instructions should be in the pocket on the wall in the main section of the tent in the pocket with red writing.
Jul 03, 2011 | Rock & Ice Climbing
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
Particular areas on my Blackberry Storm 9350 touchscreen do not respond to touch (cannot highlight or press). Also, every couple of days, the entire touchscreen will not respond and i have to 'cold boot'...
Hi, The screen of a BlackBerry Storm smartphone appears to be easily scratched or has air bubbles.So the BlackBerry Storm smartphone does not respond consistently to finger touches or slides.
This issue could be because one of the following reasons:
1) The clear plastic screen overlay that is placed on the BlackBerry Storm smartphone during the manufacturing process to protect the screen during shipping has not been removed.
2) A purchased plastic screen protector has been placed onto the BlackBerry Storm smartphone.
Still if you are facing the issue then please visit the blackberry service center or contact your service provider if it is under warrenty. I hope this information will be helpful to you
Nov 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Whirlpool Quiet Wash II center pole doesn't spin.
No. This is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit which includes the dogs, cam, seals and washers.
If you have any questions, please let me know. I hope this helps you.
Oct 04, 2009 | Washing Machines
Supressor, transient
Hello hward,
Welcome,
You said, Hello from Baton Rouge, La. just recently nailed by Hurricane Gustav.......
during the hype of the storm, I think my wife's double oven took a electric surge and started smoking. I visually inspected the damage and saw a badly burnt and scarred flat saucer looking component (suppressor, transient)...I have ordered a replacement part and would like to know if you think that replacing this item will be all I will need to do..
If the range was under water I do not think this will be the only problem.
I believe it will cause you endless problems if it got submerged!
you may end up replacing this water logged unit!
Huuum
Thank You ,Please remember to leave a rating
Sep 07, 2008 | Whirlpool RBD305PD Electric Double Oven
2005 Acura RSX
The buckle and belt need to be replaced.  They are only good for one time during a collision.  The buckle has an explosive charge in it that causes the buckle to pull back toward the seat.  The belt does the the same.  It locks up during an accident, also so body shops can't try to reuse it.  The SRS light will stay on until they are replaced.
Aug 29, 2008 | 2006 Acura RSX
Evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Dec 04, 2007 | Evenflo Aura Traditions Travel System...
Eagle's Camp Family Voyager Tent Logo
191 people viewed this question
Top Eagle's Camp Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Eagle's Camp Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
