Question about Nikon Coolpix 4300 Digital Camera
Pictures are too green
The pictures seem to have all the proper colors, but too much green. I can do some post-processing color balancing, but that isn't simple or satisfactory. The camera has a white balance feature, but only in manual modes, and automatic is the mode I mostly use.
    Genius:
  • 2,985 Answers
This could be a CCD problem - there have been recalls for some models. Go to the Nikon web site and the Technical Support Team.
Posted on Jul 15, 2007
SOURCE:
How are the calibration setting for UN60H7150
hears?
Samsung H7150 Calibration and Picture Settings 1080p 3D Smart LED TV by Robert Wiley, Senior Editor
The H7150 Series
UN46H7150 Review UN55H7150 Review UN60H7150 Review UN65H7150 Review UN75H7150 Review H7150 Calibration Notes: Calibration was very accurate and easy to aquire with the H7150 series LED TV. In fact, it is pretty close to the D6500 color temperature that our calibration shoots for. Be sure that you are changing the AutoMotion Plus feature settings depending on the programming you are watching. That is one of the most important things to keep in mind. With most programming you will want to turn it off or at least the De-judder portion. With 3D really does see a benefit from this, so you may want to leave it on. The Color Space needs no adjustments for a good calibration.
A television in the process of being calibrated before we begin our review.
Post Calibration Picture Settings Picture Mode Movie Backlight Contrast Brightness Sharpness Color Tint G50/R50 PIP Off
Advanced Settings Dynamic Contrast Off Black Tone Off Flesh Tone Color Space Custom White Balance (See Table) 10pt White Balance (See Table) Gamma Expert Pattern Off xvYCC Off
Picture Options Color Tone Warm2 MPEG Noise Filter Off HDMI Black Level Low Film Mode Off AutoMotion Plus Off Smart LED Off Cinema Black Off White Balance R-Offset G-Offset B-Offset R-Gain G-Gain B-Gain
10pt White Balance Interval Red Green Blue
Screen Adjustment Picture Size Screen Fit
(Note: Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jun 30, 2014 | Cell Phones
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
Problem with color on my lumix dmc-fh25 camera
Set the camera's white balance to match the lighting. Most indoor lighting has a yellowish cast to it, while by default cameras are set for sunlight.
Jan 10, 2013 | Panasonic Cameras
When I take pictures now with my A85 the tint is green, my pictures have more of a green tint. is there a way of adjusting the color.
Sounds like the camera was adjusted for flourescent lighting. The PowerShot should have a menu with various Lighting scenarios such as natural, outdoor, nighttime, sepia, etc. I would check this first. It should be easy to find. If you can't adjust the color properly with these pre-set options, there may be an RGB adjuster although I doubt it. You can certainly use a photo editor on your computer easily as well to adjust the color balance easily. If you don't use Photoshop there are free online photo editors such as http://www.gimp.org. You want to look for Color Balance and an RGB slide bar, it is quite fun to play around with.
May 10, 2011 | Canon PowerShot A85 Digital Camera
The tv is at least 17 years old.The blinking red light blinks 5 times ,then the tv picture goes off . The voice is still on
Five blinks is the error code for an AKB (auto kine bias) error. What this means is that the set isn't able to balance the three color guns (red, green and blue) of the picture tube properly, and it's blanking out the screen.
To get the proper colors, the signals for the three colors need to be balanced, and Sony sets have circuitry to do this automatically. Other brands don't, and when they go out of balance you see a picture that starts to show tinting or colors that are off. As the picture tube ages, it gets harder to adjust the balance until finally the AKB circuit can't anymore, and poof, the picture goes away. With a 17-year-old tube, it's not surprising.
There isn't anything that can be done to fix the picture tube, it would need to be replaced. But the cost of the tube and the work required to get it set up after installation makes it completely uneconomical to repair this TV. A new picture tube is nearly $200. Then special tools are required to set the tube up (a process called convergence), so you'd need to find someone to put it in, and possibly pay to have the old one disposed of. A new 32-inch LCD set is around $350 now. Treat yourself to a new one.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Green pictures panasonic fz7
Check the WHITE BALANCE settings and the COLOR EFFECTS settings (marked as W. BALANCE and COL. EFFECTS when MENU is pressed).
When you got to the MENU setting, press up or down arrow until you reached either selection, press the left arrow, and you'll see several options under the selected function. In WHITE BALANCE, there's an option whether you'll be shooting under sunny or cloudy skies, tungsten or flourescent lighting, and an option to select Auto or Manually set White Balance. This affects the over all color tone as it compensates the color correction depending on your shooting conditions. Fluorescent lighting for example exhibits blue spectrum, thus setting White Balance to FLUORESCENT will add warm or yellow tones to the photo. Tungsten lighting and sunny conditions exhibits yellow lighting, and setting to the White Balance on this mode will add cool or bluish tone to the picture.
Same with COLOR EFFECTS: settings include WARM, COOL, SEPIA or BLACK AND WHITE (gray scale).
Chances are, you have accidentally set the WHITE BALANCE or COLOR EFFECTS to any of these. To see if this is the problem, try shooting under SIMPLE MODE (Marked with a HEART icon at the rotary dial on top right of the DMC-FZ7). If the problem goes away, then it is with the WHITE BALANCE and the COLOR EFFECTS settings. Try setting the COLOR EFFECTS to "OFF", and the WHITE BALANCE to "AUTO".
If all else fails, then you got a problem with the image sensor of your Panasonic DMC-FZ7 Digicam
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Site Creator, TEENMODELS2007
http://teenmodels2007.wetpaint.com/
Sep 27, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Saturation of unrealistic color
It is definite CCD chip problem. If you are within warranty period, send it back quick. They probably replace with other unit because the parts are not available for the product. Good luck.
Mar 13, 2007 | Apex Digital 4330z Digital Camera
Nikon D70 Help
I don't think there is really any such thing as a 100% "natural picture". What your eyes see and what film or a sensor "see" are not the same. All photos are manipulated to some degree whether it be from the type of film or the digital "modes" you use. If you would have shot with a film such as Velvia, the greens may have been more "stellar" or maybe too green. There are a number of settings you can use to get the results more to your liking with a D70, or shoot NEF and post process to your liking. Your exposure will make a difference so you may want to bracket.
Sep 14, 2005 | Nikon D70 Digital Camera
Nikon Coolpix 4300 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
