Question about Dryers
Gas dryer heating system is not igniting - Dryers
  • scwisher May 11, 2010
    Can you see if the ignitor is glowing after dryer runs for 30-45 sec?
    Sniper:
  • 50 Answers
Remove acess panel in front of dryer you will see a grayish ceraminc coil. turn on dryer an see if that coil gets red. if not unplug dryer and remove burner there should be one screw thatsecures igntor gol-bar in place remove screw and visually in spect coil you will see wher it is broken replace it and put burner back in dryer and go
Posted on Jan 25, 2009
Dryer stopped heating how do you light the pilot
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.
Mar 14, 2011 | Crosley Dryers
The dryer is spinning but no heat what so ever...help!
HELLO THERE
There's no heat If your dryer doesn't heat, check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer doesn't heat up
Hello there
PLEASE READ THE ENTIRE SOLUTION
Sep 28, 2010 | Whirlpool GGW9250PL Gas Dryer
No heat
Hello there:
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Sep 26, 2010 | Roper RGK2951W Gas Commercial Dryer
GE Dryer model DWSR405GB0WW Gas dryer will not heat up when auto dry cycles are used (thatt use automatic sensors, such as the permanent press dry cycle or the "auto dry" cycle). Only works in manual timed...
Hello there
when a gas dryer will not heat up properly there can be several different reasons i will try to explain them here for you ok
No heat If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Mar 29, 2010 | Dryers
Gas will not ignite
Dec 31, 2009 | Kenmore 74112 Gas Dryer
Gas dryer ignites at start up then cycles off, won't re-ignite
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedures for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
The link below shows an image of the gas valve coils, which is the most common failure component in the system.
1. Gas Valve Coils:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG3000AWW-%3d%3di3479&PartID=3479
Below are some tips to follow if the coils are not faulty.
Igniter
Gas valve coils
Thermal fuse
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 28, 2009 | Maytag Dryers
I have a gas dryer , dryer only runs on air. There is no heat. What is causing the problem? Please advise!
Igniter
Gas valve coils
Thermal fuse
Aug 03, 2009 | Dryers
Dryer turns on and spins, but will not heat and dry clothes
Here is a quick course on the reasons why a gas dryer won't heat. If you are not mechanically inclined you will have to get a repair man because none of these reasons are quick fixes.
Igniter
Gas valve coils
Thermal fuse
May 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer working but no heat
If it does not heat , and you already checked the burner and the ignitor, then it is probably the thermal fuse at the back of the appliance.
See the following suggestions from Repairclinic:
Igniter
Gas valve coils
Thermal fuse
Oct 09, 2008 | Dryers
Dryers Logo
Top Dryers Experts
