Question about Car Audio & Video
Realistic 80w 80w model 12 1960 power amp
Wiring dia
X-sectional area of a power cable is 1000 sq mm-how can i understand?
This is a common way of specifying an electrical conductor. The wire is almost certainly round, and may have more than one strand.
XSA = PI * R^2 where R is radius, so a single strand of that XSA is 17.8 mm radius or 35.6 mm dia.
If the conductor has 10 strands, each is 100 sq mm and therefore 5.6 mm radius or 11.2 mm dia.
Nov 26, 2015 | Cars & Trucks
Wiring dia. yamaha c3 scooter
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Yamaha C3 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha XF50W Service Manual
OEM parts for Yamaha
Yamaha XC50Z Owner Manual
Jan 13, 2012 | 2007 Yamaha C3
Need wiring dia on 98 yamaha yzf 600r
Hi can anyone be generous and email me a wiring harness for a 1998 yamaha yfz600r ninja wiring diagram for wiring harnesd
Aug 17, 2010 | 1998 Yamaha YZF 600 R thunder cat
Need connector wires inside wand. Electrolux central vac. 16" wand 1 1/4" wand dia. Don't need wand, just the wires.
Go to a store like Lowe's and look in their electrical department. You need wire the same gauge size (stranded or solid) and comparable insulation. Hope this helps!
Jan 09, 2010 | Vacuums
Simplicty lawn tractor wiring dia 14hp briggs straton
Have you priced a wireing harness they're not that expensive and fairly easy to change and may solve your problem quicker and cheeper in the long run.
Dec 04, 2009 | Garden
Oh and what do i
TORQUE VALUE CHART
7/16" dia. 50 to 60 lb-ft
12mm dia. 70 to 80 lb-ft
1/2" dia. 80 to 90 lb-ft
5/8" dia. 110 to 125 lb-ft
*Use this chart to get correct torque values for each size wheel stud. I hope this helps and don't forget to rate my answer.
Feb 01, 2009 | 2002 Chevrolet Malibu
I require a wiring dia for kelvinator N395BGWH no frost model
What is the fault you are trying to eliminate? There is a possibility that the fault is other than in the wiring. Check on the back of the unit as wiring diagrams are sometimes attached to the back wall of the refrigerator.
May 16, 2008 | Freezers
Replacement screws for connecting the power wires
The smaller screws should have been 5mm dia with a 0.8mm thread pitch. The larger ones are probably 8mm dia. with a 1.25mm thread pitch.
Is 5/16 too large or too small? If 5/16 is too large, the screw is probably 7mm.
Do you have one of the original B+/ground screws? If so, it should be easy to measure it and get the correct size.
Apr 25, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Split AC install
1. mind it - its a very simple installation
2. connect suction (or big cu. dia tube) connection to cond. unit (outdoor unit) big valve.
3. same way - liquid conn.(less dia tube) to small valve (liquid valve) in outdoor unit.
tight flare nut properly
4 provide power to indoor & run the same wire to cond. unit , you must hv got the ins. kit with wires and cu. tubes.
5. or read wiring diagram given of units for wire.
connect as per wiring dig. provided.
ravi
Jan 30, 2008 | Samsung AS18A6RB Air Conditioner
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
