Beko WME8227B not draining - Washing Machines
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: beko wme8227b washing machine
It is a common fault that the drain fails to work inmost machines in a period of time and is the most problematic fault in awashing machine. In all occasions it is important that your observation is mostimportant and so is vital to the identification /rectification and solution. Ifyou have noticed that water has leaked then as the drain hose pump/valve andfittings are located on the underside of the machine it is important that youlook for possible leaks here. In some cases the drain hose would be clogged atthe drain end to outlet of the house and so there will be back flushingresulting in overflow to the outside. Also the drain pump/valve can be clogged.Now remove the drain hose clamps and remove the drain pump/valve, clean thedrain pump/valve, use back flushing to clear off all dirt. Now test using powerto see if this works and can be simulated. When refitting, the hose must be tightenedproperly. If the pump/valve does not work even with power then it must bereplaced. If there is intermittent powerto the drain valve/pump then the program controller unit is a suspect.Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use aspirit level- so that all water will drain to the outlet port and thereby thereis no residual water remaining. Replacing the pump on a Bosch machine, please checkthis link for tips:http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jul 05, 2012
caroldon
  • 17130 Answers
SOURCE: eo5 beko wme8227b
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
My beko wahine machine wont drain
This Beko washing machine video will help you
Buy Paul Beer
Feb 10, 2014 | Washing Machines
Beko washing machine WME8227B. Switch on power, set programme ,press start button, hear the door lock (noticed that the padlock symbol isn't on as nomal) no water flows , checked manual eg child lock, time...
Probably a fault with the lock or latch; should be no problem for an engineer to fix. Just try giving the door a firm push to close it, to see if the padlock light comes on.
Jan 10, 2018 | Beko Washing Machines
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Beko wme8227b washing machine
Jul 04, 2012 | Washing Machines
Eo5 beko wme8227b
Hi if your beko wme8227b washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jul 04, 2012 | Whirlpool Washing Machines
Beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
May 21, 2012 | Beko WM5140W
Have a beko washing machine and the water will not drain! Any ideas PLEASE
hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
Jan 29, 2009 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
Top Washing Machines Experts
