Question about Water Heaters
Maxistore water heater manual
How to set up
Can I find an owners manual for my water heater? If not, can someone help me understand how to determine the temperature setting in degrees?
Easiest way to do this is to set the water heater in the mid range and wait for it to heat and settle down, then take the temperature of the water from the drain valve. See if it is too hot or cold. Raise or lower it a little at a time and wait for it to settle. Check it again.
Nov 07, 2014 | Rheem 22V50FN 50 Gallon Ultra Low Nox...
We have a 2006 31 ft fleetwood prowler trailer. We can't find in manual switch for water heater. We see the switch with electric and gas on wall but which symbol is "on" &...
I do not have specific answer.
Open following links to identify product, download service guide and download manual for the different model numbers, plus parts list and other resources:
Page 3-4 of following manual shows switch settings for LP gas.
On-line manual can be word-searched for 'switch.'
This water heater has remote switch, which is the switch you are talking about. It also has limit switch and ECO (energy cut-off switch)
http://waterheatertimer.org/pdf/Atwood-installation-maintenance.pdf
http://waterheatertimer.org/pdf/Atwood-Water-Heater-Service-manual.pdf
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jul 26, 2011 | RTO Atwood Water Heater - 6 Gal LP
How to change temperature setting
Link below shows step-by-step for typical tank-type gas and electric water heaters
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
If water heater used to be hotter, look at diagrams following link:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Other water heater tips and tricks:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
If you have tankless water heater, consult manual.
Changing temperature on tankless can lead to problems.
Tankless should be de-limed each year to maintain efficiency. U-tube search 'delime tankless'
Read the manual for yearly maintenance requirement.
All costs are energy, and tankless are maintenance heavy.
Mar 08, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I turn the bottom thermostat down to 110 degrees. What should the numbers be?
Many times there are no numbers on thermostat since temperature settings are approximate.
Link below shows step-by-step temperature adjustment for typical tank-type gas and electric water heaters. Residential electric tanks can usually be set from 90 to 150, and gas from 50 to 150.
Use cooking thermometer at water heater drain valve for more precise reading.
Mar 07, 2011 | RELIANCE ELECTRIC WATER HEATER
Trying to find temp dail
You posted under Reliance point of use electric water heater.
Open following link to access manuals:
http://www.reliancewaterheaters.com/lit/om/e100.html
Thermostat has adjustment screw.
Open access door on side of water heater
See diagram of thermostat and approx settings:
All water heater temperature settings are approximate.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#Reliance
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 19, 2011 | Reliance & Electric Water Heater
Need to know minimum and maximum manifold pressure settings for a rheem tankless water heater. Model # RTG-74PVN-1
Please review the Rheem water heater manual below. Page 18 will give you the manifold pressures.
I hope this helps you...Jim....Please leave a comment if this information helped.
http://www.heater-home.com/manuals/DirectVentManual.pdf
Feb 13, 2011 | Rheem Water Heaters
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
Oct 28, 2010 | Intermatic WH40 - Water Heater Time Switch...
Whirlpool Energy Smart Water heater - light is solid green then every now and then blink a couple of times then go solid again.What does this mean?
2 flashes = high water temperature (the water heater comes set at 120, and you can set it lower or higher)
3 flashes = sensor failure (temperature sensor similar to a thermostat on regular water heater)
4 flashes = upper element
5 flashes = lower element
Links below are for Whirlpool manuals
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
The water heater is working right now.
If the elements go out, they are available at any hardware store.
The temperature sensor is easily replaced and can be ordered from Whirlpool.
You might want an extra temperature sensor on-hand so repairs are not delayed.
Link below shows the product in detail.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Let the water heater do its job until it fails.
Oct 22, 2010 | Water Heaters
Manual lever setting for water heater timer
post a close up of the timer and i will tryto assist you.
normally it dosent matter where the lever is as it should reset itself after each comlete operation . ie if you turn it on it should turn off when it reaches a preset off cam pin. or position indicator lever.
Nov 25, 2008 | Intermatic WH40 - Water Heater Time Switch...
Water Heaters Logo
113 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
