Question about HP DesignJet 1050c plus InkJet Printer
Hp design jet 1050C code close right door to continue
efs_perpends
  • 1996 Answers
SOURCE: clear print jobs on hp design jet 1050c
Depends on your OS. In general: see here. or here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 28, 2009
kipfixer
  • 5 Answers
SOURCE: My Design Jet 1050c does not like to print PDF's.
Two questions:
1. How large is the PDF file and is saved on your local hard drive?
2. How is the plotter connected to your computer? Network or directly connected via parallel or USB?
Try changing how the printer processes the print job.
On the driver properties / preferences, select the Advanced tab and change the Process Document to "in computer" and then try printing again.
Posted on Aug 31, 2009
  • 96 Answers
SOURCE: HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Posted on Sep 09, 2009
  • 10 Answers
SOURCE: HP desk jet D2345 Status reads: door open.
I just help a friend with this problem, I just had her to restart her computer and now she can print and the "close door" message is gone.
Posted on Aug 31, 2010
  • 4044 Answers
SOURCE: When I go to print
To be honest this sounds like a driver problem. Go to the HP website, www.hp.com, and download updated drivers and software for your printer and Operating System. If you have upgraded to Windows 7 but are still using the Vista driver set which is possible it will cause this problem.
Posted on Nov 18, 2010
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
We installed the HP designjet on a pc windows vista and we can print everything we want to, the printer is also installed on a mac osx 10.6 snow leopard but there we have some problems for printing our...
HP Design Jet 1050C Plus is supported by MAC OS 10.6. If you are having problems with printing, it is recommended that you may update the drivers of your printer. Click here to download the latest drivers.
Good Luck!
Hope this helps!
CreativeTECH
Dec 15, 2010 | HP DesignJet 1050c plus InkJet Printer
SYSTEM ERROR CODE 04C300 C8CC0000 THEN STOPPED PRINTING MIDWAY THROUGH JOB iT SAYS TO HIT ENTER TO CONTINUE BUT GOES INTO A LOOP OF ERROR CODE /HIT ENTER, ETC
This is an IO error. Remove the back cover and disconnect the cables to the HDD and remove the JetDierct card. Print the internal test page. If it prints OK, install the Jet Direct card. Print again. Prints OK? Replace the HDD (or run without it). Does not print OK?
Replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Dec 16, 2009 | HP DesignJet 1050c plus InkJet Printer
I am getting a system error 0C003200000003 HP designjet 1050C
System Error: 0C0032 (Continuable)
Problem
Description:
Drop Detector not Calibrated for all Printheads.
Corrective Action: Try the following:
n Perform the Service Station Calibration þ
n Replace the Drop Detector Assembly þ
n If the Error Code continues, replace the Electronics Module þ
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed
this is a continuable error.
Sep 25, 2009 | HP DesignJet 1050c InkJet Printer
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
My Design Jet 1050c does not like to print PDF's. It says receiving low memory right now and is taking an extremely long time
Two questions:
Aug 06, 2009 | HP DesignJet 1050c plus InkJet Printer
Clear print jobs on hp design jet 1050c
Jul 28, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
HP Design Jet 600 Plotter
The problem the 'alignment error' this causes is car desalignment, is need repair phisical.
May 29, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
