Question about Philips Magnavox Learning Universal Remote
Convert 480i to 720p
I have a insignia 32" plasma 720p
i have a scientific atlanta explorer 8300hdc
the cable box is reading 480i
i want to change it to720p?
how??
ty
Connect an Hdmi cable from the tv to the receiver
Posted on May 26, 2009
Turn off cable box.
Turn on TV.
Hold down media and guide for a few seconds.
On TV pick the resolution you want. Your choices are 480i, 480p, 720p, some wide screen resolutions and 1080i.
Save the results.
You should be good to go.
Posted on Apr 15, 2009
Can I connect a Toshiba DVR620KU to a scientific atlanta explorer 4200 cable box?
Please follow guidelines given in operation manuals of both.
Aug 02, 2012 | Televison & Video
I can't turn on closed captioning on Hitachi with Comcast scientific atlanta explorer 2200 cable box. Any words of wisdom?
Both the set and the box used should have the closed caption feature.
If box is in line to rear audio/video jacks you will have to engage the CC from the box.
I doubt it will work if hooked that way from within the box---go to menu and in CC area in either set or box select CC1 which is the most common one used.
May 25, 2012 | Hitachi P50H401 50 in. Plasma HDTV
720p is putting out signal of 480i or p only
Your Tv has its own settings for high definition.
Look in your manual for appearance setting and turn the tv to 720p high definition.
That should be enough. OH! And make sure your PS3 is set for HD output too! My HD tv downconverts occasionally when the Uverse box shuts off and defaults to low def output.
Feb 03, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Scientific Atlanta 3250HD cable box that loses sound everytime a channel is changed. The box must be rebooted to get the sound back each time. I have no problems with the 4250HD boxes. Any...
Did you call Scientific Atlanta to find out if this could be a software issue in their box, or if there is a failure occurring?
I have had cable boxes do similar things to what you are describing. It turned out to be the box was defective and had to be changed. They were not serviceable. I believe these cable boxes were made by Scientific Atlanta.
Jerry G.
Nov 14, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
HDTV and cable box; no volume on channels higher than 99
Can you tell me, is the set top box connected directly to the tv? (i.e. not to a surround sound receiver or anything)
Mar 13, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Feb 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need TV code for Emerson HDTV LC320EM8A
I am looking for a remote code for the emerson LCD to work with the Comcast remote...any suggestions?
Dec 08, 2007 | Emerson EWL3706 37 in. LCD Television
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
Philips Magnavox Learning Universal Remote Logo
639 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
