Question about Bonavita Ellie
Drop side retrofit kit + Lajobi Inc - Bonavita Ellie
I have a crib, model 1404 86, bought in 1986. Is it still safe?
Performa Google search for the answer to this.
Sep 05, 2017 | Baby Gear
Where is the low side port for the 1990 ford ranger
1990 Ford Ranger was equipped with an R-12 system (Unless it has been retrofitted) The low side port for those systems were usually on the suction-side reciever/drier. I have also seen upgraded hose kits installed on some of these vehicles (for retrofitting purposes) where the port is on the hose assembly between the drier and the compressor or even on the compressor manifold itself.
Apr 08, 2011 | Ford Ranger Cars & Trucks
How do i get directions for assembly and use for crib
These cribs were recalled. Please check yours on this list.
Also call them anyway and ask for a free set of instructions especially if it is recalled!
http://www.cpsc.gov/cpscpub/prerel/prhtml10/10212.html
Remedy: Consumers should immediately stop using the recalled cribs and contact LaJobi to receive a free hardware retrofit kit that will immobilize the drop side. CPSC urges parents and caregivers to find an alternative, safe sleeping environment for their baby.
Feb 22, 2011 | Graco Lajobi Kendal Convertible Crib
I am missing the guide parts that are moving the front mobile gate up and down on the crib.i had this crib for 7 years.is a graco 2 in 1 crib.can you please tell me where i can find the parts?
Graco is not a manufacturer of cribs, they sell their name to crib makers. Currently, LaJobi is the maker of Graco cribs, and they offer a Lauren crib (which was recalled!). But, you say this crib is 7 years old? That is before LaJobi made their cribs (I think). Check the labeling on the crib (on the headboard, under the mattress) and see if the actual manufacturer is listed. If you are looking to replace a plastic part for the drop side, then I recommend you don't bother and just get rid of the crib. Those plastic parts are connected to the drop side by screws, and removing and replacing a screw into wood makes the wood weaker in that area. You take the chance it will never be tight and if it falls off in the middle of the night, that could be a deadly consequence for your baby. That is why so many cribs are being recalled now. The drop side hardware breaks, parts get lost, and for a few unfortunates, this results in a child dying.  Check the label, see who makes it and whether or not it was recalled as shown in this link: http://www.cpsc.gov/cpscpub/prerel/prhtml10/10212.html
Sep 27, 2010 | Graco Lauren Crib
I went on line to try to get a manual, and found out my crib has been recalled. I bought it in 2006 at walmart will they rerfund for it?
I believe that this particular recall is not a traditional recall so to speak. A recall does not mean that they're actually recalling them, but more so it indicates a problem with the unit itself. This particular recall involves a kit that will fix the issue... The problem identified is reports of the side dropping down unexpectedly. The fix is a kit that they will send out, that will keep the drop down side from moving at all.
Here is some information about the recall itself, as well as a phone number to call regarding the recall.
The recalled wood cribs came in cherry, espresso, natural and white finishes. The name "LaJobi" and the crib's model number can be found on a sticker on the stabilizer bar or on the bottom rail of the crib.
The China- and Vietnam-made cribs were sold nationwide from February 2007 through March 2010 for $140-$200.
If you have one of the cribs, you are asked to stop using it until you receive a hardware kit from LaJobi that will immobilize the drop side.
For more information, call LaJobi at (888) 842-2215 or visit the company's website.
~Marianne Is-Loved~
Sep 19, 2010 | Simplicity for Children 8994W Crib
Can't find model # or serial#
I fudged it, a little. Got a model number from the alert, and used it on the manufacturer's website. Model number here:
http://pregnant.thebump.com/new-mom-new-dad/baby-gear/recalls/safety-alert-massive-recall-on-graco-and-simplicity-cribs.aspx
And don't waste time calling, use the link here:
http://www.lajobi.com/
to fill out the form to get the repair kit.
Apr 30, 2010 | Graco Lauren Crib
I have a graco lauren dropside 3 in one convertable crib. Has a recall been issued?
Yes it is! Go to http://www.lajobi.com/ and order your free retrofit kit. Click on Product recall 2010. You just need your 7 digit model #. They will also ask for Name, Street Address, City, State, Zip Code and telephone number. Then you will either get a message saying that your product is not under recall or the kit will be shipped in 2 to 3 weeks! I hope this helps!
Mar 06, 2010 | Graco Lauren Crib
Where do you recharge the airconditioning unit on a 98 jeep grand cherokee 4x4 loredo? Need the location of the fill valve. I already have the recharging kit.
Jeep GrandCherokee SUVs manufactured in or before 1995 use R12 refrigerant. You must retrofit these SUVs to accept R134 refrigerant using a retrofit kit available at your local auto parts store before you can recharge the system. In some areas, a license is required to retrofit an air conditioning system. If this is the case in your area, take your Jeep to a professional to retrofit the system.
Instructions:
  1. Step 1 Take your SUV to a mechanic to recover the R12 refrigerant out of the air conditioning system. A license and special equipment are needed to do this. Because R12 refrigerant is expensive, many mechanics will do the job for free.
  2. Step 2 Locate the Low Pressure Side connector port. You will find it on the driver's side of the engine. Remove the blue or yellow cap marked L. You only need to retrofit the system if you see a screw-type connector valve. If you see a quick connect valve, the system already is R134 compatible. Wipe the connector valve off with a clean towel. This ensures that the retrofit connector properly adheres to the valve.
  3. Step 3 Place the long retrofit connector from the automotive retrofit kit onto the Low Pressure Side valve. The retrofit connector has a special adhesive on the threads that will help it adhere to the valve. Screw the connector onto the valve. Tighten the retrofit connector using an adjustable wrench. Place the cap provided in the retrofit kit onto the retrofit connector. This keeps dust out of the system.
  4. Step 4 Follow the air conditioning lines away from the compressor until you see the High Pressure Side port valve. This is located near the Low Pressure Side service port. Remove the red cap and wipe the port off with a towel.
  5. Step 5 Put the shorter adapter onto the port. Twist it using an adjustable wrench until it is securely fastened to the port. Place the red cap from the retrofit kit onto the adaptor.
  6. Step 6 Fill out the Retrofit Identification sticker provided in the retrofit kit using a permanent marker. Remove the protective backing and place it on the interior side of the hood. This lets future owners and service professionals know that the system has been retrofitted.
  7. Step 7 Recharge the air conditioning system. See the related eHow titled "How to Recharge Air Conditioning with Freon in a Jeep Grand Cherokee."
WARINING:
Never try to evacuate the system yourself. A license and special equipment is needed to evacuate the system. Attempting to do this yourself will release refrigerant into the air, which is a federal crime.
Good luck (rated this help).
Aug 10, 2009 | 1998 Jeep Grand Cherokee
Lowering the Mattress
Call LaJobi (the manufacturer) and ask.
LaJobi 877-440-2224
Jan 19, 2009 | Graco Lauren Crib
Bonavita Ellie Logo
21 people viewed this question
Top Bonavita Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Bonavita Baby Gear Expert? Answer questions, earn points and help others
