Question about Motorola Mobility H700 Wireless Headset
I cannot switch calls with the H700, how due you check battery
Does the battery work when you press the top and bottom button at the same time?
  • 25 Answers
The manual suggests pressing the call button and thats supposed to toggle between as many as 3 calls. good luck
Posted on Jan 26, 2009
H700 motorola will not go to pair mode
With the boom "closed", depress center button until it is purple. Release the button and extend the boom. The light should now be a constant purple, and in pairing mode.
Aug 27, 2009 | Motorola Mobility H700 Wireless Headset
H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
Aug 02, 2009 | Motorola Mobility H700 Wireless Headset
Im trying to sync my H700 bluetooth to my Sprint Palm phone.I have used code 0000 and 1111 and neither is working?
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on the headset is charged before doing this.
If this doesnt work: Start the search on the phone, Keep the boom of the mic closed when you press and hold the button on the h700. the light should turn purple. After this, open the boom
If it asks for a passkey, it will be 0000, four zeros. This is the default passkey for the Moto H700.
Jul 25, 2009 | Motorola Mobility H700 Wireless Headset
No voice dialing
hi when you press and hold the button you redial the last call, and when you press just once quickly this button your phone pass in voice call( if your phone has this function...lol) and don't forget to activate the function voice call in your cell phone.
hope this helps you
sserpentio
Feb 12, 2009 | Motorola Mobility H700 Wireless Headset
Redial last number called when turning H700 on
If you are turning it on with the button, that is why. To turn on the H700, you should just need to open the boom mic. Once open, it should connect with your phone. The H700 is designed to dial the last number when the button is pressed. No way around this one.
Dec 01, 2008 | Motorola Mobility H700 Wireless Headset
Power won't come on
I am having similar issues. Before you OPEN the boom, press and hold the CALL button in the middle and ensure your Bluetooth is paired/synced with your cell phone.
Press and HOLD about 5 seconds until the PURPLE light illuminates. Then flip it open immediately and begin the pairing process.
My problem is that the purple light won't illuminate at all...
good luck
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
Pairing h700
try pressing firmly against the hinge area, press the call button until the purple light comes on, then open the boom with still pressing firmly on the hinge. Keep holding firmly and the purple light should stay on while you pair
Nov 16, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Volume 'Up' Orientation
There is a way to change the orientation of the earpiece and volume buttons. Guest's comment was uncalled for. Suppose you are deaf in the ear that it comes set up for?
Nov 01, 2007 | Motorola Mobility H700 Wireless Headset
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
20 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
