Question about HP Pavilion dv6000z Notebook
My mic is real Low
Every time i go to use my mic it is really low i have gone and turned everything up but it hasnt seemed to work can anyone help me fix this plz
  • 68 Answers
Try this,
double click on your volume icon on the taskbar(the one at the bottom on the right side)
select option, check all the box, many option will appear, uncheck all the box(the box which make the funtion mute) and maximize all.
or find free software for mic
Posted on Jan 25, 2009
Seems as if all the senors in my car is going. I have the dash "low coolant" light on but coolant is fine. I also have a sensor in my front passenger side door gone and now my turn signals aren't
These are not really sensors but switches. The low coolant one if the tank is full is defective it is located in the coolant recovery tank. The door has a defective door ajar switch in one or more of the four doors, have a dealer scan the systems control module for id of which sensor it is, to replace them requires the door be taken apart a very time consuming job if you have to remove all 4 door panels.
Nov 30, 2012 | 2002 Ford Taurus
Suction problems with hood fan Inca Smart 70
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 08, 2012 | Kitchen Ranges
Friend with AVR 335 is experiencing very low subwoofer output to powered sub - has to be turned up to max for any sound at all and really just produces low rumble - no real impact - have tried sub with my...
Why aren't you looking at the sub for the reason? It may have the crossover set too high.
If the sub is loud enough during level setting, look at receiver settings, otherwise it's the sub amp.
Feb 10, 2011 | Harman Kardon AVR 335 Receiver
CB receive volume is low to out on the output. Weatherband output and reception is fine. Any suggestions?
The problem could be with the mic. If there is a problem with the mic it will make either the receive not work, or the volume seem real low. The weather will work fine if the mic is bad.
Sep 29, 2010 | Radio Shack TRC-447 CB Radio
2007 Buick Lacrosse low beam headlights both went out at once. Doesn't appear to be the bulb. Also checked the fuses under the hood and those both appear OK too.
The relay under the hood may have gone out. We had the same problem on our 2007 Buick LaCrosse CX. The bulbs were fine, high beams worked, all turn signals and everything except the low beams turned on. Turns out the relay had gone bad.
Sep 07, 2010 | 2007 Buick LaCrosse CXL Sedan
The sound is really low, it only works for 3 seconds when I turn on the phantom power and then it goes really low almost soundless
are u sure the type of mic ur using is made for phantom power? if it is. try opening up the gain on the sound board just a tad. if that doesnt work turn the master slider up. try other mics and see if it isnt ur soundboard or speakers
Jun 24, 2009 | MXL Audio Players & Recorders
My Tungsten T3, from time to time, turns itself off within 2-10 seconds after I turn it on. The delay is random; the problem is random (it doesn't do it for weeks, and then it apparently goes into a snit...
Issue rather seems software related, if Battery issue usually comes up with low battery alert.
A full (Hard) reset can be a good solution to be sure if its Software related. If you do so make sure you have backup of all your data as full reset will set everything to factory default and will erase the personal data
Good Luck
Mar 16, 2009 | Palm Tungsten T3 Handheld
Headset Doesn't Work...
hi Ive got a logitech headset 250 but I cant use that in my laptop and why !??
pleale help me!
see yah bye for now
Nov 13, 2007 | Logitech 250 Headset
Mic don't work
I replaced this unit with another one I got on Ebay (different brand). Had the same problem! So I figured I was doing something wrong and I was. Eventually I disconnected the digital coax (which I was using for top quality) and just used regular A/V leads. Apparently digital coax can't take the Karaoke music AND the mic audio across to the receiver at the same time. Everything works now. Hope that helps you.
Feb 01, 2007 | RSQ NEO-E500 DVD Player
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
