Question about Acer Aspire 5315 Notebook
CODE 39 DISC DRIVE CIRRUPT
I HAVE ALL A SUDDEN DEVELOPED A CODE 39 WHEN I TRY TO USE THE DVD DRIVE.
    President:
  • 1,257 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on Jun 27, 2009
  • 64 Answers
You need to install the latest driver for your device...
http://laptop-notebooks-drivers.com/tag/aspire-5315-pc-notebook
official bits from microsoft:
Code 39
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Recommended resolution
Reasons for this error include a driver that is not present; a binary file that is corrupted; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.
Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Posted on Jan 25, 2009
MY TOSHIBA DVR MODEL DR420KU WILL NOT RECORD ON DISC. IT KEEPS GIVING AN ERROR CODE AND NOW IT WILL NOT PLAYBACK DVD-R DICS, BUT IT WILL PLAY MY DVD+R DISCS. WHAT COULD BE THE SUDDEN PROBLEM?
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU optical pickup contain lasser beam, NOT are reading the TOC from DISK+ Syscon can be defective, you must go to the repair shop TV for fix it see the diagram attached, is a complex equipment.
God bless you
Jul 16, 2012 | Toshiba RS-TX20 DVD Recorder
DVD/CD drive won't recognize discs. System says corect driver installed
Is it a disc that someone made on their computer and gave to you or is it one you purchased from the store? Computers sometimes have a hard time reading a disc that someone made and gave to you. Try a disc that you purchased and see if it plays it.
See if you can update the driver in the device manager.
Uninstall the DvD Drive from the device manager, then reboot and let it reconfigure everything. Go the Control Panel and under System find the device manager. Right Click on the dvd drive and select uninstall. Reboot.
Reseat the the disc by unplugging the power cord, remove the battery, then turn the laptop over and remove the screw that holds the dvd drive in place. Pull the drive out, then put it back it.
If you are using Windows Media Player try the VLC player.
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
Apr 14, 2012 | Computers & Internet
I keep getting unrecognized disc half of the time i put my game in the Xbox 360. I check the games, not scratched, and seldom dirty. Then I hit the y button for status code and it tells me 03-57-00. ...
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Sep 13, 2011 | Video Game Consoles & Games
How do I remove write protection from a DVD-RW?
Your M35X-S1143 model - assuming it still has the stock drive - has an DVD / CD-RW optical drive - i.e. it will write only to CD's but not DVD's. If you try to burn a DVD, it'll tell you that the disc is write protected (when in fact, the drive doesn't even know how to write to a DVD disc.); if you go ahead and burn a CD, you will not encounter the write protection warnings.
Aug 31, 2011 | Toshiba Satellite M35X-S1143: M35X-S1143...
Hi this is peter i have a problem hat i nt figer out. trying to install Punch Home and Land Premium i get this-- Error 1305.Error reading From file C: Program Files\Punch! Home and Land Premium\ tool...
Hello peter4927,
An, "Error 1305" message mean that; your computer is unable to read the "Program Disc" properly.
This error can occur if your CD or DVD is damaged, dirty, or caused by dust.
This can happen, if another program is "preventing your computer from reading the "Program!"
You will also receive this error if the "Disc Drive" is damaged or dirty.
Try cleaning the "Disc" first!
"Use a Disc Cleaner, to clean the CD-ROM / DVD Drive.
Place the "Program Disc in the Disk Drive; then "Restart the Computer!"
This will have the CD, or DVD start-up {Automatically}.
Next, you can try to start the "Disc" by using the "Auto-Run."
To do so; place the 'Disc' in the "Disc Drive Tray."
Next, [right click] on the "Computer Icon" to open the 'computer window'.
Now, right click, on the Disc Drive, and select the either, "Open, Explore or {Auto-run}.
Hopefully it will start.
Repeat each action if necessary!
"If there is anything else, you may need help with?
Write a 'comment,' I'll be here to assist you!"
"Best Regards"
Jul 28, 2011 | Punch Home and Landscape Design Suite for...
Blank DvD Disc Reading Problem
Goto HP's website to the support section download the drivers and replace your current ones. If it still does not the drive has failed and needs replacement.
Thanks Frank Z.
http://www.codebluehelp.co.cc
3868607368
Jun 29, 2009 | Computers & Internet
Can I burn to disk a movie from my hard drive "avi file format"and play it in a dvd player
you cant play avi on normal dvd player,but you can convert avi to dvd format by use free softwere ( filmMachine )
Aug 10, 2008 | Panasonic Televison & Video
DVD ROM CANT READ DISC
Please go and buy a new dvd writer in place of dvd-rom.
Dec 05, 2007 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Acer Aspire 5315 Notebook Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
