Question about Home Security
I have a Grundig tv WF70-3020, when turned on this afternoon, the
Screen came up with Protected and the security details which were put in to the tv when we bought it 6 0r 7 years ago, but never activated the security protection. We recently acquired a Matsui TV which we are using separately for the Wii which did have security protection on it so we turned this off. Has this affected our Grundig TV as I understand they are made by the same people. We have tried turning everything off and unplugging but no luck as yet. Can anyone help?
Thank you
The installer code is 3477, switch off the tv and unplug from the mains and leave for at least 30 minutes before trying this when you switch on your tv it will ask you for a pin code - use the installer code and it works just fine :)
Posted on Feb 21, 2009
Why does grundig tv have a blue screen ?
It's not detecting a proper input. You will have to tell it what input to use most likely, or it is bad.
Nov 28, 2015 | Grundig Televison & Video
Grundig TV - Colours all mixed - still have fullpicture
Hi rosscop
You have a magnetic interference problem. First, have you put any magnetic objects like speakers near the set recently. They will cause this. Turn the set off at the wall and wait for 15 mins for the PTC device that turns on the degauss coil to cool and operate. It is the loud burst of hum you here when you turn the set on from cold.
0083efa.jpgThe PTC is a postive tempeture coefficient that allows alot of current to flow at first, heating up as it does, and then slowly less current as it heats. This is why you need to turn the set off and let it cool. If the problem remains The PTC may be faulty allowing too much current to flow and upsetting the magnetic flux about the tube. If you dont have the skills you will need a technician to sort it out for you.
Aug 25, 2008 | Grundig GF70-600 TV
Security code
I can't find the GF70 manual but hopefull below could provide some clue to your problem The original key # is 0000 http://www.grundig.co.uk/content/ug/GUVCD2800.pdf?language=en-GB This is new model of grundig and should be using the same method on the lock key. Refer page 22 of 42... Will dig out my old datasheet folder . this might take sometimes... Hope this helps...
Aug 21, 2007 | Grundig GF70-600 TV
My grundig t.v p 37-06 cuc 630 is locked with timer on the screen.how do i get the code?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jul 03, 2015 | Grundig Televison & Video
Grundig lenaro tv stuck in standbye mode cannot turn tv on with remote control
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device; (here it is "Grundig"), in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 06, 2015 | Grundig Televison & Video
Grundig lcd tv has vertical purple lines that fade after a few minutes
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 07, 2014 | Grundig Televison & Video
Hi, Please somebody help me. I repair a faulty grundig plasma tv. At first it has no picture because the STK795-820 (YPPD) IC and the fuse was broken. I changed these and now it works, but the picture is...
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 30, 2017 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
Grundig televideo, put the wrong code in now protected
just take the batteries out and put them back in and if not hit the code search button and enter the code
Jun 29, 2009 | Televison & Video
Tv protection
Hi.
The set is expecting a pin number to be inserted.
If you dont know or cant remember pin do this.
USE REMOTE CONTROL AND BRING T.V OUT OF STANDBY,
SCREEN REQUESTS PIN CODE,
PRESS STANDBY, PRESS NO. 7 BUTTON FOR 6 SECONDS, THEN IMMEDIATELY PRESS STANDBY (THERE MUST BE NO DELAY BETWEEN LAST ACTIONS).
Do this to the letter it should sort out your problem.
http://dysonmanuals.llc.nu/
Jul 15, 2008 | Televison & Video
Home Security Logo
378 people viewed this question
Top Home Security Experts
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
