Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
This tv has inbuilt freeview, how do i use a dvd recorder to record off it?
The dvd recorder i'm trying to use is wharfedale dvdrhd400 and i can pick up the 5 terrestial channels but am unable to pick up the freeview. cheers Tom
  • 3 Answers
The Wharfdale Machine that has Freeview has an F on the end ie vdrhd400f. It may be yours is an analogue version. Always possible that you can use the TV as an output via a scart to record what you are watchin
Posted on Jan 28, 2008
Wharfedale 80GB DVD HDD Recorder DVDRHD400 USER
remote not operating, unit working otherwise, h/d not full, dvd's play ok
Oct 26, 2009 | Televison & Video
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Progresive scan problem and didn't get picture in tv
Our problem was that we could not get picture on the tv screen but it got sound.We tried to solve it using different techniques like the setup,video source,function keys pressed on remote control by trial(only assumed) and error as we could not see the screen and I used scart with every conection but three point pin was free so I put only one pin in video out put and at that moment I could see the picture on tv.
Jan 30, 2009 | Wharfedale DVD-M3 DVD Player
What are the correct connections for a wharfedale 80GB hard disk drive with freeview to a wharfedale digital TV with freeview and a dawoe video recorder?
Hey matt here, From memory I think it tv- video via scart and then scart or avr to HD. Hope this helps. Matt. Please Rate me
Dec 31, 2008 | Televison & Video
WHARFEDALE DVDRHD400
when you have split and seperated the part of the viceo you want to put onto a dvd, highlight it on the list of recordings and press the blue "playlist +" button on the remote. This will have added the recording onto the list of items to be recorded to dvd. Now press the red "RECORD/DUB" button. This will then record the file to the disc.
When y ou are notified that the process is complete,you will need to finalise the disc in order for it to be playable on other machines.
While the DVD is still in the drive uses the blue "function" button, and select DVD.
Shortly a list of titles on the DVD you have recorded will appear. Press the "UP" arrow on the remote once and a new menu will appear. One of the options here is to finalize disc. hilght this option and click the "RIGHT" arrow once - press "select" to finalise the disc.
Aug 30, 2008 | Wharfedale DVD-M3 DVD Player
DVDRHD400. No volume on the TV channels. Will play sound on DVDs but no volume on anything recorded from telly. I have adjusted volume, on tv, cable, dvd but no luck. HELP me too please !!!!!
hello ,i fixed this problem on a dvdrhd400 i picked up off ebay with same fault. played dvds perfect but no audio coming in from freeview or scart (this is not a firmware update problem). the problem seems to be the capcitors on the tuner board (long retangle board at back which scart connects to) theres a 100uf 10v-16v capcitor (sorry cant remember if voltage was 10v or 16v as i fixed this a month ago and system as been working perfect and dont want to take it all apart again) its in the middle of the board off to one side with afew other 1uf caps around it. replaced it with a 100uf 25v cap (higher voltage is fine as long as same value) Capcitance meter was reading cap as bad. bingo worked perfect ever since.
Apr 12, 2008 | Wharfedale DVD-M3 DVD Player
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Error code
I had the same problem - turn off at the wall and on again fixed it.
Dec 07, 2007 | Wharfedale DVD-M3 DVD Player
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Jun 25, 2007 | Wharfedale DVD-M3 DVD Player
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
