Question about Toshiba Satellite U305-S7448 Notebook
My Toshiba P305D S8836 won't connect to my TV
I've connected my PC to the TV using S-Video Cables. The only activity i get is a flicker on the screen when i attempt to make a connection. My buddy uses an older model Toshiba and he connects to TV with no problems. I'm not understanding what's going on with my PC.
  • uconn_ap Jan 25, 2009
    I haven't installed any new video drivers. I did decrease the notebook's screen resolution, and i've adjusted the control panel to connect to external display. I have not seen any recognition in my control panel regarding the type of TV that i've connected the PC to.
  • Misterixas May 11, 2010
    Does your notebook have installed the latest video card drivers?
    Have you tried to decrease notebook's screen resolution to 640x480?
    Does your video card's control panel (or settings software )recognizes attached TV set?
  • 55 Answers
Have you pressed the Fn button and the associated F key to transfer the signal to the S-Video output? If so you may need to configure the display setting for monitor 2 in the display setting in control panel as it will differ from the monitors settings.
Posted on Jan 25, 2009
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
My toshiba satellite battery is not working.
Buy a new battery for ur laptop...otherwise buy a new one...
Aug 25, 2013 | Toshiba SATELLITE P305D-S8836 Laptop...
Battery doesn't work.
Batteries degrade over time. Replace the battery
Aug 25, 2013 | Toshiba Satellite P305d-S8836...
Lost bios password on toshiba satellite P305D-S8836
Lost BIOS password?
If you can remember, it will be much better,
If not, try rebooting in safe mode as administrator(hold down F8).
Else you need to put a second disk in another PC and run some password reset utility likeWindows Password Recovery Basic. http://www.windowspasswordrecovery.net/
If all these can't solve the problem, you have to reinstall the PC.
Nov 02, 2010 | Computers & Internet
Change video output to s vedio connection
If the computer does not easily and automatically show the computer screen on the tv through the S-video output, make sure the tv is switched to S-Video and Hold down the Fn + F5 keys to toggle through the video output manually on the laptop. Just make sure that only one video source is connected at a time. Your laptop will not support two output sources at the same time. Below is the user manual in which it discusses the use of an external device on page 70.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2059997&rpn=PSPC0U&modelFilter=P305-S8832&selCategory=3&selFamily=1073768663
Oct 31, 2009 | Toshiba Satellite P305D-S8834 Notebook
Laptop to tv problem
This is pretty common if using S-video connections and quite often there is little that can be done apart from use high quality cables.
Even that is not always 100%
A better option if you can is to use component cables or DVI to HDMI which is the best way.
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it. and I suspect that is what you have.
Sep 15, 2009 | Toshiba Satellite L305-S5933 Notebook
My laptop acts funny, its a toshiba satellite p305d-s8836. The dvd door keeps opening on its own, and when i do put a dvd insde it wont read the disk.
This is bcoz your dvd palyer has to serviced. Pls consult to ur local service engg & if this is under warranty call them..........................Sameeraryan
Jan 19, 2009 | Computers & Internet
Toshiba 30HF84 and progressive scan
check your connections properly there could be some thing that you are not connecting .or your cable are not compatible.good luck
Jan 23, 2007 | Toshiba 30HF84 30" TV
Toshiba Satellite U305-S7448 Notebook Logo
199 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
