Question about Canon PIXMA iP4000 InkJet Photo Printer
Cannon PIXMA Service Error
PIXMA iP4000 printer flashes sercice error 5100, how do I fix this please?
  • 4,041 Answers
Hi You can Try 2 things.
Have a go
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Error 5100, place help me
Please let me know if you see any lights flashing or what exactly happens when you get this error. Can you also confirm the model number of your Cannon PIXMA IP, I cannot find the 1300.
Thank You,
Brian
Feb 06, 2011 | Canon PIXMA iP1300 Printer
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
I am getting service error 5100 while trying to print page..the page passes through but nothin is printed....suggest me a solution????
- Carriage unit
- Carriage motor
Nov 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Solve error 5100.cannon pixma 145 error always out # 5100
5100 error is a carriage error. Could be caused by the carriage unit, timing strip, logic board or carriage motor. Check that nothing is obstructing the carriage from moving freely and that the clear timing strip is ok.
Nov 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Everytime I try to print Error 5100
Hi, Error E22 5100 is a carriage error. Check that nothing is stopping the cartridges from sliding back or fore acroos the silver bar inside the front of the printer.
Nov 05, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
see if that helps
Robert
Please rate this solution thanks
Aug 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
Service error in canon pixma ip 1200??
Hello,My problem its Pixma IP 1200 for Windows Vista PLZ Help!!!
Jun 16, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
359 people viewed this question
old marine
old marine
