Question about Brother LS-2125 Mechanical Sewing Machine
Timing on a brother sewing maching LX-1120
Need instructions on how to fix the timing with pictures and where the timing adjustment screw-nob is. Took maching to repair shop and the advised me the timing was off and didn't pay to have it repaired. they wanted to sell me another maching so i left. on you product type you don't have this particular model, so i just put down any model so my question would go through. it is a brother LX-1120. my email is likeitislii@aol.com Thanks, George
  • likeitis Jan 29, 2009
    SEnd a picture if you can. It won't pick up the thread from the thimble spool. Can't see how the tension is doing anything. When the guy in the shop looked at it, no thread was used at all. The machine is a brother LX -1120 not a LX 2125. Thanks
    New Friend:
  • 186 Answers
The timing is set on the lower shaft on the left end. Needle bar rise is 2.5mm. Check your timing belt tension to prevent this in the future.
Posted on Jan 29, 2009
  • SewTechWayne
    SewTechWayne Jan 29, 2009
    I goofed, the timing is set on the right end of the lower shaft.
    Note: all Lx machines are essentially the same.
Brother sewing maching
On the hand wheel there is the lock that is used to stop and start the needle from being used. This is necessary for refilling the bobbin with thread. If the hand wheel doesn't make the needle work then you will need to do some minor adjustment.
1. On the hand wheel find a small screw and loosen it until it is just about ready to remove.
2. Now tighten the hand wheel.
3. Tighten the small screw again.
It should be ready to use now.
Aug 31, 2016 | Brother Sewing Machines
Manual brother vx-1130
Sue, I will post links below for your manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Brother VX 1120 User Manual
Brother VX 1120 Sewing Machine Threading Diagram
Manual BROTHER VX1130 Operating Instructions Service
Brother VX 1120 Sewing Machine Troubleshooting eHow
Mar 03, 2016 | Brother Sewing Machines
Brother 1120 sewing machine timing adjustment
Easy to do remove sole plate remove shuttle and case, don't forget to pull the spring loaded plate to one side by inserting a electrical screw driver in the slot and twisting it anticlockwise to release the case, remove drive dogs this will the expose the cotton pickup assembly turn the hand wheel anticlockwise until the hook gets close to the needle now watch the needle it should be in the lowest position and just as it starts it's way back up the hook should be just going behind the needle to pick up the tread if this is not the case and it's out of position then hold the hand wheel tight and insert a small screw driver into one of the gaps in the base were the shuttle case fits in away that you are able to move the hook assembly one way or the other with a gentle pressure and move the hook just to make it enter just behind the needle as it only just starts it's way up at this position it is now complete and you can reassemble and run slowly at first just to make sure things are okay.
Happy Sewing
Oct 15, 2011 | Singer 1120 Mechanical Sewing Machine
How do I replace the needle in a Brother CS-100 sewing maching?
Go to www.brother-usa.com and under support pick home sewing group, then select your model, cs 100t and download a free manual. It will show you where the screw is located, do not remove the screw, just loosen it.
Apr 17, 2011 | Brother CS-100-T Computerized Sewing...
I lost my sewing maching manual and need to know how to thread the machine...
Go to www.singerco.com and download your manual for free. Just go under customer support and put 1120 in the box. good luck
Sep 28, 2010 | Singer 1120 Mechanical Sewing Machine
Free tech support on how to change a need in a brother pacesetter XL3001 sewing maching
turn the screw on the needle bar a little until you can pull the needle saftely out
put a new needle back in with the back ( which is the flat side) of the needle facing the back of the sewing machine & tighten the screw back up
Jul 20, 2010 | Brother Sewing Machines
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
325 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
