Question about Sharp Office Equipment & Supplies
Need pcl5 driver for Sharp MX 363 - Sharp Office Equipment & Supplies
3 Suggested Answers
SOURCE: can't find sharp ar-bc320 driver
Sharp does not natively support or provide a PCL6 driver for this device. That being said, another possible workaround to provide you with a PCL6 driver for this is to try the HP Universal Print Driver for Windows PCL6 x64bit. This driver simply prints direct to the IP address that the printer uses on the network. You may sacrifice a few special features of the device using this driver, but I've had excellent success with it and recommend trying it.
Here's a link to the driver:
http://hp.driversdown.com/hp-drivers-download/HP-Universal-Print-Driver-for-Windows-PCL6-x64_18967.shtml
Hope this helps!
Posted on Jun 20, 2011
  • 18 Answers
PCL6 Printer Language is (or shall be) device-independent. However, not all (indeed none) of printers support the full set of commands. If you cannot find the driver provided by SHARP, you can use HP Universal PCL6 Driver, *or* HP LaserJet 4050/4100/4200 PCL6 driver from Microsoft Windows system. The 4000 series printer drivers use only OLD & BASIC commands. Although these printers are B/W printers, the PCL6 commands sent to the printer support color as well.
Posted on Nov 02, 2017
Where can i get driver for Sharp MX-3500N
Hi
If you go here
Download Centre
then there is a list of 43 drivers, 7 Operational Manuals, and 15 Software items, all of which can be downloaded for installation, reference etc. You will need to go through the lists and download those you want/need, or even maybe all of them. I don't know if you will need to register with the site or not, but even if you do, it is Sharp's own site and all the items will be free of charge.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 19, 2014 | Sharp MX-3500N Multifunction Printer Color...
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
Sharp MX-M260 Copier Machne
Check if you have the right driver, it could also be that you don't have a scan function and need to pay for it.
For drivers check:
http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=MXM260&cat=341
Dec 10, 2013 | Office Equipment & Supplies
How to install hole punch setting on pc
You need to configure your print driver with the options that the machine has. Check out my How-To configure the sharp print driver.
How To Configure Sharp Print Drivers with Installed Options to print...
Aug 23, 2013 | Sharp MX-5111N Copier w/ 36 Month Warranty
Can't find sharp ar-bc320 driver for 64bit, there's only PCL5 driver which won't work, we need PCL6 driver for this model.
Hope this helps!
Jun 20, 2011 | Computers & Internet
Driver download
You need to go to the sharp usa site. You will go to office products and search ar5316. They have a driver section there and you can download one of probably 3 drivers. I would suggest PCL5 or PCL6 for black and white copiers. PS driver if you copy a lot of PDFs.
Aug 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
Where can i download the drivers for a sharp mx-2600/3100 printer?
www.sharp.net.au > support > drivers > Photocopiers > MX2600 > then chose Operating System (OS) > GO
Jun 02, 2010 | Sharp MX-2300N Color Copier
Hello i have copier machine sharp mx-450u,with mx-nbx3.some times when i print document.suddenley stop printing,so i turn it off then it start printing,allways same ****.so i dont know the proplem cause of...
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Jun 17, 2009 | Sharp Office Equipment & Supplies
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Oct 09, 2008 | Sharp Office Equipment & Supplies
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
