Question about IBM ThinkVision L151 15" LCD Monitor
IBM Thinkvision Monitor Error
The screen is set at 90 degrees.. how to I get it back?
  • 689 Answers
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Posted on Jan 29, 2008
    President:
  • 2,961 Answers
If you right click on an empty space on your desktop and click properties, your graphics adapter driver settings should appear, look in the settings and you will have the option to rotate the screen back to normal.
Posted on Jul 14, 2007
Verticle thin blue line on my IBM ThinkVision Monitor?
it may be a permanent damage on your monitor. i think it is unrecoverable.
Jul 16, 2017 | IBM ThinkVision L200p 20.1" LCD Monitor
What large lcd monitor can I buy that will best display a full 8.5x11 page and still let me be able to read the type?
Some wide-screen monitors have a "rotate" option in the software that comes with the monitor -- you physically rotate the screen 90 degrees, and then Windows will rotate the entire "desktop" so that you now have an "extra-tall' screen, instead of an "extra-wide" screen.
Jun 09, 2010 | Lenovo ThinkVision L192 19" LCD Monitor
Ibm thinkvision monitor problem
I would try it with other PC, if it is still doing the same thing and you want to DIY repair, then please read below.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | IBM ThinkVision L170 17" LCD Monitor
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
Laptop doesn't see the monitor i attach to it
1st off there is a Fn key, I think Fn + F5? to turn the monitor on. It is a toggle button that toggles between only the monitor or monitor and Laptop screen both or just the laptop screen.
I hope that can help, if not, please tell me what you have tried. As in, does the monitor work on another PC/Laptop?
G'luck
Oct 24, 2008 | IBM ThinkVision L170 17" LCD Monitor
Ibm thinkvision l170 monitor
Hi! Tammy,
It's seems your new pc resolution settings, set to high...
Hook up to another monitor and go to settings to correct your
resolution to 1280x768 or less. That will fixed your problems.
Good lucks!
Aug 07, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L151 15" LCD Monitor Logo
218 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
