Question about Epson Stylus CX3200 All-In-One InkJet Printer
EPSON stylus CX3200---printer error check documentation
Loud buzzing noise when started for few seconds. won't copy
  • gramonster Jan 29, 2009
    I did a head realignment because the printer wasn't printing each line clearly. After this, it not only didn't fix it, it made it inoperable. When I turn the machine on, the inkjet carriers try to locate to the right and a horrible noise ensues. The error light comes on.
I followed one of the solutions listed---and it worked!!!!
Posted on Jan 26, 2009
Printer error see your documentation and call service if ....
i have epson stylus cx3200 error see your documentation and call service
Oct 01, 2012 | Epson Stylus CX3200 All-In-One InkJet...
Bought new cartridged, replaced the old one but the content is not getting printed
Check the control panel for error indicators. The error light is to the left of the display and is marked "Error," it will illuminate. The error will appear on the screen and is in plain English, so very simple to interpret. An example is "Color or Black Ink Out," meaning there's no ink.
  • 2 Verify that the Epson Stylus CX3200 is connected to the printer with a cable. Try connecting without a USB hub while troubleshooting---that way you can identify if the problem is with the hub or printer. Replace the cable, it may be bad.
  • 3 Print a nozzle check pattern to determine the extent of the problem. The nozzle check will allow you to determine whether the printer will print at all, and the results will give you a good indication of print problems. Press the Menu button on the Control Panel until you see Nozzle Check and press the Color Copy button.
  • 4 Replace the printer cartridges if the Control Panel suggests you do so. Press the Menu button until you see "Change Cartridge" Press the Color Copy button and the cartridges will move to their change position. Lift the scanner and unclamp the cartridge. Replace the cartridge---color is on the right and black on the left. The Epson Stylus CX3200 will start charging the cartridge and after about thirty seconds the printer will be ready for use.
  • Feb 07, 2011 | Epson Stylus CX3200 All-In-One InkJet...
    Epson Stylus CX3200 Error
    Possible scanner failure.
    Turn off your printer. Disconnect it from your computer. Toggle the transportation lock on the scanner unit if there is any. It has to be in the unlock position. Turn the printer back on.
    If your unit is not yet a year old, please contact epson for your warranty options.
    To help you find an epson certified servicer near to your area, please log on to epson.com.
    Apr 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
    Error inkcartridge
    Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
    Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
    Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
    Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
    Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
    Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
    Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
    Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
    Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
    Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
    Error Message: Scanner unit open -- > close the scanner unit
    Solution: Carefully close the scanner and press it down until it clicks securely into place.
    Error Message: Scanner error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
    Error Message: Printer error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
    Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Scanner error message
    Cannot print document and scanned on it.And make important copies.
    Sep 12, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Help Epson CX3200
    I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
    May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
    By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
    May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Epson cx3200 printer has printing problem
    Hello cockie ,
    You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
    If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
    It may also be helpful to try running a printer nozzle check.
    See the following message problems and solutions:
    Error Message Probable Cause No color or black ink cartridge - - >
    The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
    The indicated cartridge is out of ink Ink cartridge error - - >
    There is something wrong with the ink cartridge. Paper jam or misfeed - - >
    Paper is jammed. Press the Color Copy button to clear the jam.
    See the User's Guide for more troubleshooting tips.
    Paper out - - >
    Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
    Close the scanner unit.
    Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
    See your documentation and call Service if necessary.
    Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
    Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
    Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Epson Stylus CX3200 All-In-One InkJet Printer Logo
    574 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
