Question about Bosch Washing Machines
Replace door handle for bosch wvf 2402
This is a bosch washer/dryer small plastic handle has snapped I have replacement but cant see how to take door apart to fix it
SOURCE: Bosch WVF 2402 Washer Drier Steam Problem
Hello All
Problem solved by clearing out the condensate container which on inspection was full of dried up fluff and dead tissues! This is not a ****that is mentioned in the manual and access to the bin is pretty tricky so I suspect there are lots of machines out there with the same problem waiting to happen.
Access was gained by taking the top of the machine off, removing the dryer motor and then scraping out the muck using a wire coathanger and a vacuum cleaner.
Many thanks
Andy Wray
Posted on Mar 10, 2008
  • 1294 Answers
SOURCE: Splendide 2000S
Go to: repairclinic.com
Posted on Mar 13, 2008
barkencoa
  • 3463 Answers
SOURCE: my Bosch WVF 2402 will not drain
Tyere should be a filter located at the bottom right front of washer, behind a drop down cover.
Unscrew anti-clockwise to remove and clean.
Posted on Dec 30, 2009
SOURCE: maytag 1275 front loader. plastic inside part of
Hi Liz, I to have the same problem, a design fault! It was $35AU for the part, I have replaced it but the door can't close properly. Still working on it. Joan
Posted on Jul 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: can't open front door of washing machine
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Bosch classixx wvf 2402 at the end of the dry spinning cycle, 5-6 minutes the machine makes a terrible noise. What could this be?
Can you describe the noise? Is everything else working normally? From what you are saying, my guess at this point would be that the pulley on the motor is working loose.
Jun 13, 2014 | Bosch Classixx WVF 2402 Front Load...
Bosch classixx wash and dry - washing machine works fine but dryer does not start and door light does not go out?
if the door light is not going out it is an indication that the door switch is not working. this would also cause it to not run because it thinks the door is still open.
Mar 27, 2013 | Bosch Classixx WVF 2402 Front Load...
Washing machine door not opening
If the unit has not drained fully the door will not open, check the filter for foreign objects and then put the machine on spin cycle, check the door after this. Worst case scenario is the the door handle was pulled too hard whilst the door was still locked and the catch has broken. Post if more assistance reqd
Feb 20, 2013 | Bosch Classixx WVF 2402 Front Load...
My Bosch WVF 2402 will not drain
Dec 30, 2009 | Bosch Classixx WVF 2402 Front Load...
Timer switch has broken on bosch wvf 2401 how to replace?
First remove screws X2 from back of the machine that hold the top cover on. Once removed the whole top slides backwards and can then be lifted off. This gives you access to the plastic clips that hold the timer face panel on. The main control dial must first be pulled off through the front cover, then remove the front cover by unclipping it (a pain and a fiddle!) The dial on the timer can then be pulled off revealing the two mounting screws that hold the timer in!!
Feb 02, 2009 | Bosch Classixx WVF 2402 Front Load...
Hello All
Many thanks
Andy Wray
Mar 08, 2008 | Bosch Classixx WVF 2402 Front Load...
Replacement door seal/gasket
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Apr 08, 2007 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
