Question about Panasonic Audio Players & Recorders
Panasonic; SC-HC35DB DAB wont work with supplied aerial
Supplied aerial not good enough
2 Suggested Answers
SOURCE: SC-HC35DB DAB RADIO HAS STOPPED WORKING , ALL OTHER PARTS FINE ,
You need to tunr the power off at the wall socket. Leave the unit off for at least 5mins. Then whilst holding the power on button on the unit down, turn the power back on at the socket, keep the power button depressed for at least 5secs. When you release it you should see -----------------, in the display. The unit has just been reset to factory mode. All features should now be present again. Hope this helps.
Posted on Jul 22, 2012
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Why wont my makitaq dab radio work ?
Not enough signal? Power supply faulty? Switch faulty? It's broken?
There is not enough detail in question even for a mind reader like me!
May 12, 2014 | Makita BMR100 Radio
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
May 02, 2012 | Panasonic Audio Players & Recorders
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
Speaker wire
Use the same gauge that is supplied for the rear. Probably 24 gauge.Do it with the power off. If the wires touch with the power on the rear output IC will blow. Good Luck
Dec 11, 2008 | Panasonic SC-PT660 Theater System
Since a storm the dab function on my SC-EN29 COMES UP DAB AUTO SCAN F26 DAB DDOWFIC i cannot get any stations
It is a loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Panasonic Audio Players & Recorders
Panasonic SC-EN17. F76
you wil have to subtitute a tech for a dealer instead.they will be able to help check along the left side of the home page for fixya and try to locate a repairman near you just put in your area code.good luck.
Apr 06, 2007 | Panasonic SC-EN17 CD Shelf System
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
