Question about LG WM1814CW Front Load Washer
How do you change filter
How do you change the filter assembly
    Sergeant:
  • 291 Answers
There is no filter to change. But there is a basket attached to the drain pump that needs cleaned frequently. The basket acts as a filter by catching coins, lent, bobby pins, etc. and preventing them from entering the pump. There is a small door at the bottom left of your machine. Use a blunt screwdriver or even a coin to pry the door hatch open. Once open you will see a large screw cap and a thin drain hose. Release the drain hose from it's anchor point, hold it over something to catch water and open it. When you are satisfied it has drained you will need to unscrew the drain pump cap. Careful there could still be water so prepare for that. Usually these will unscrew one full turn and a little more before remaining water starts to flow from them, let it finish draining (a shop vac with paper filter removed works great to catch remaining water) before completely opening. When cap is loose pull the basket straight out, it's probably full of a few treasures so don't just dump it in the trash. Also, watch out for poky sticking things when looking through it. After dumping it's contents rinse it under running water. If it smells of waste water and/or has blackish water see if it looks like it will pry apart (sorry not sure about yours.) If it will pry apart it should do so fairly easily but be careful of it's contents, not only is it stinky but it can leave permanent stains in clothing, curtains, etc. Rinse that out and pop back into place. Next shine a good light into the pump assembly itself and up it's hose. Stick a finger into the pump housing and see if the impeller feels straight and moves (it will naturally resist you) if it feels jambed try to unblock it. If the impeller feels bent it will need replaced (likely you'll have to buy the entire housing.) Once you are satisfied the pump should function and the drain hose leading to it is cleared you can put the basket back in.
I like to put a healthy glob of petroleum jelly on the threads and O'ring of the basket assembly before reinstalling. The basket part slides in open end up there is a notch in the cap that aligns with a groove in the housing then screw on till it stops (about three full turns.) Cap the drain hose reattach to it's anchor and close the hatch. Start the machine. Now would be a good time to run a cleaning cycle with recommended amount of bleach. Or whatever you prefer to use.
Here is your owner's manual if you don't have one:
http://www.retrevo.com/support/LG-WM1814CW-Washers-manual/id/438ag212/t/2/
It's got a troubleshooting section that may assist you in the future.
Hope this helps.
Posted on Jan 19, 2013
Where is the fuel filter for 2005 Chrysler 300 seems the car is having trouble getting the gas
I believe it is part of the fuel pump, so if you are going to change out the filter you probably should change out the entire pump.
The pressure regulator/filter assembly is the very top subassembly in the fuel pump module. The filter is built into the regulator assembly.
Jun 02, 2017 | Chrysler Cars & Trucks
How do I install a new filter on a mazda b 2300 series pick up truck
well it certainly depends on what filter you are going to change .
Mar 29, 2015 | Mazda Cars & Trucks
I have a Lincoln Aviator 2003 and i want to change a gas filter how i do it
The fuel filter is integral with the electric fuel pump assembly, which is inside the tank.
To change the fuel filter, you will need to replace the entire pump assembly (~$400). This can be done by draining the fuel from the tank, removing the tank, replacing the assembly, and reversing to reinstall it.
May 09, 2011 | Lincoln Aviator Cars & Trucks
How do I change fuel filter on a 2005 suzuki reno? Can I find detailed instructions on the internet? Thanks for any help.
You can access the filter, it is part of the pump assembly inside
the tank. You have to remove the entire pump assembly thru the hole under the
back seat. Once that is out, you have to disassemble it as well to access the
filter. It looks like a little semi-circle/half moon shape mesh material. Only
problem is that the dealer does not sell this filter seperately at all. To get a
new one, they will tell u that you have to buy an entire new pump assembly. awcforever_6.jpgTechnically they made it so you don't have to change it. SOrry.
Mar 11, 2011 | 2005 Suzuki Reno
2007 hyundai santa fe fuel 2.7 6 cyl fuel filter location?
how to change the fuel filter on 2007 hyundai santa fe
Sep 20, 2010 | 2007 Hyundai Santa Fe Limited
Replacing air filter on 2000 buick lasabre
To change the air filter disconnect the electrical connector on the large hose that runs from the air filter assembly to the throttle body assembly. Slowly and carefully remove the large hose from the throttle body and air filter assembly. Some of the 2000 models have spring type clips holding filter cover while others have two screws. Either unhook the clips or ree.move the screws and lift the cover. You'll see the filter element. Remove and replace it. Reverse order to reassembl
Sep 14, 2010 | 2000 Buick LeSabre
Hello, I was just wondering how to change the fuel filter on a 2005 mazda 6 v6?
Mazda Car 2005-06 Repair Guide
Fuel Filter Removal & Installation
The fuel filter on most Mazda cars can be located on a bracket in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir or as part of the fuel pump assembly.
The filter on Mazda3 models is part of the fuel pump assembly.
The fuel filter is part of the pump assembly. Once the fuel pump is removed, remove the filter retainer and filter. refer to the fuel pump procedure or removal and installation.
Hope helps with this (remember rated this help) Good luck.
Jan 12, 2010 | 2005 Mazda 6
Where is the fuel filter on a turbo desail
Your fuel filter is mounted on the rear of intake manifold, under air cleaner or on rear firewall.
Just a little hint on replacing it, remove your fuel tank cap to release pressure or vacuum in the tank. I'm sending you a diagram the fuel filter assembly so it will make it a little simpler for you to replace your fuel filter. Start by removing the filter element nut. Remove filter element by lifting straight out of filter housing. It is not necessary to drain fuel from filter housing when changing the filter element.
Installation, ensure mating surface between filter element assembly and filter housing is clean. Install new filter element by aligning widest key slot located under element assembly cap with widest key in filter housing assembly.
Tighten element nut by hand. Bleed air from fuel manager/filter assembly. Connect a hose to air bleed valve and place other end of hose in a container.
Disconnect fuel injection pump shutoff solenoid wire. Crank engine for 10 to 15 seconds. Allow starter to cool down for one minute between cranking intervals. Repeat procedure until clear fuel is observed at the air bleed hose.
Close air bleed. Connect injection pump shutoff solenoid wire and reinstall fuel filler cap. Start engine and allow to idle for five minutes. Check fuel manager/filter for leaks.9df1ca0.gif
Oct 03, 2009 | 1994 Chevrolet C/K 2500
How to Change the idler-arm assembly in a Kenmore
remove lint filter, two screws below filter. using putty knife unclip corners of main top, remove two screws inside front panel(1 on each), remove belt, drum and idler. hope this helps
Aug 17, 2009 | Dryers
LG WM1814CW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
