Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
My hd tv
Im new to hdtv.. and i dont know how to view hd materials on my hdtv, even viewing from my hd cam to tv. help me.
    President:
  • 2,961 Answers
To view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Posted on Jul 14, 2007
SOURCE:
Will my camcorder still record even though I can't view playback
If you cannot view action on the cam screen and likewise when attaching it to the TV; the video playback function has been compromised. You may be able to record as the two functions are separate from one another, however what good is recording when it cannot be played back? If the Recorded material is on a Tape or CD and you can move material to another reading device or player; then your problem is answered.
Dec 25, 2013 | DigiLife DDV-C330 Digital Camera
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
How do i connect my hdmi cable from my ibuypower desktop to my sansung led tv?
Make sure the input on the TV is set to hdmi port 2. If it doesn't automatically view on the TV, you have to go into the graphics card adapter settings to set the view to an alternate monitor (your TV). Normally there's also a hotkey command as well (normally one of the F# keys) to switch between displays
Dec 20, 2012 | iBuyPower Gamer Computers & Internet
I am having a problem with my new vizio tv. I am
Try this solution....
1) On the original TV remote press the menu button.
2) Scroll down to SETUP and press MENU button to select it.
3) Scroll down to WIDE
4) Use the LEFT and RIGHT arrow keys to adjust to your viewing preference.
**** NOTE: When you adjust these settings you may notice a difference in the picture on the HD channels. When you are viewing an HD channel but the network is not broadcasting that show in HD they push in the sides to compensate and try to make it a sharper picture but know this is normal.
Good Luck and please rate this solution....
Jan 10, 2010 | Vizio VF550M 55 in. LCD HDTV
I am getting a blue screen that says mode not supported when I try to view HD channels
This usually indicates that you are trying to watch a screen in a higher resolution than the Tv will actually handle
Aug 17, 2009 | Televison & Video
Program the hd channels
The FLM-2601 is an 'HD Ready" TV but does not have an HDMI input or a digital tuner, it only has an analog tuner. You will need a cable box or other source to view HD. Using the component inputs (YPbPr) you can get up to 1080i.
Apr 21, 2009 | Polaroid FLM-2601 Television
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Cant view web cam in yahoo messenger
the drivers comes with the webcam you have, or download from internet, i need to know what webcam you have.
Jan 07, 2009 | Yahoo Messenger
Unable to view fullscreen in hdtv
That is the way HDTV is viewed on many screens as a wide fromat. So you will get top and bottom non-viewable areas. It is the width that gives the full imagery for that format. To have the screen filled you would get a standard 4:3 format like standard TV. HD is a 16:9 format so it is much wider.
Sep 22, 2008 | Panasonic CT-32HX40 32" TV
How do I get HD broadcasts on a Phillips 60PP9352 TV that's 'HD ready'?
Hi.
Im guessing your in the UK.
Asking about HD as you havent stated what country you are in.
Ok You will need the following to be able to watch HD pictures on your tv set.
Either Sky HD which involves having a dish fitted. Or Virgin cable system which is not available all over the country.
If you go to either of these systems you will need to pay a subscription to view the HD channels.
http://dysonmanuals.llc.nu/
Chris..
Jan 01, 2008 | Televison & Video
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
