Question about LG 50PS11 50 in TV
LG plasma 50ps11 wont turn on
It just clicks and the light turns from red to blue blinks two or three times and goes back to red
stradeteox
  • 88 Answers
SOURCE: LG plasma won't power up
There are many different parts that could cause this problem. I would suggest letting the repair center have your unit to troubleshoot the exact cause. The most likely cause is that either your Y sustain board or X sustain board has gone out. It could also be a bad power supply or one of the Y drive boards. Without checking voltages and proper troubleshooting it is difficult to go any further.
Posted on Jan 08, 2009
lightnbaby
  • 36 Answers
SOURCE: LG 50PC3D PLASMA WILL NOT TURN ON
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you save $300 least!
Posted on Mar 15, 2009
dave1645
  • 834 Answers
SOURCE: lg 26lg30 light blinks red blue wont turn on.
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
Posted on Nov 06, 2009
  • 8457 Answers
SOURCE: LG plasma just turned off for no reason,
Try unplug,replug for reset that all could do,same prob.must change tha Main backlight Vivdeo board.
Posted on Nov 17, 2009
freelance-au
  • 131 Answers
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
Posted on Apr 05, 2010
My LG Plasma 60" 60PG60 TV refuse to turn on. Red button light comes on but the blue light flashes and turns off. No picture, no sound. Please Help.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 25, 2016 | LG 60PG60 60 in. Plasma HDTV
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
My lg plasma tv when we turn it on blinks green 2 times then goes back to red
check for shorted components on YSus board and Y Driver boards (the boards on the left with the back off) This job is for a tech type person.
May 16, 2014 | LG 42PC3D 42 in. Plasma Television
My Zenith plasma TV blinks green 4 times then goes red, No picture. None of the Capasitors are blown.
I had AWFUL customer service. (Sherry is DREADFUL her # is 1-877-543-8325 she is in"executive services". Ask to speak to her directly...if you would like ZERO help.)
They WILL NOT extend the warranty, even though they know there is a defect with this AND other models. Zenith name on the front...LG guts in the inside.
Ours turns on, screen black and then clicks three times and then turns back off.
Jul 13, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
Jan 06, 2009 | LG 50PX5D 50 in. Plasma HDTV
LG Plasma wont turn on
yeah I'm miles from the nearest town with a 2 hour drive in any direction. With same problem ! Good news is i dont care how dumb a person is a 1st grader could fix this one. very simple to correct. contact PartStore.com order a power supply and replace it yourself, nothing difficult at all about this one ,so long as you can handle a screwdriver.
Jan 05, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Th-50pz80u turns off for no reason
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
Dec 13, 2008 | Panasonic TH-50PX50U/P 50 in. HDTV Plasma...
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
LG 50PS11 50 in TV Logo
185 people viewed this question
