Question about Kenmore Washing Machines
I have a kenmore top load washer model #11091210100 where is the lint trap?
  • Kenmore Master
  • 17,130 Answers
Posted on Jan 19, 2013
SOURCE: Maytag Atlantis top-load washer has a big lint problem
My dryer is making a noice and will not start how do I open it to see if the belt is broke
Posted on Jan 17, 2009
mark_37388
  • 100 Answers
SOURCE: just looking for the lint trap on my washer
It does not have one
Posted on Mar 30, 2009
jsrock516
  • 5911 Answers
SOURCE: need to know how to clean lint trap and where is
The only trap on a Kenmore Elite HE3 is in the drain pump. The following link explains how to access and clean it out:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provided and let me know if you have any questions. I personally own one of these washers and have repaired them many times. If you are experiencing drain problems, the problem will most commonly be attributed to the drain pump trap becoming clogged with debris. There's usually an error code associated with this problem of "F02". If you attempt to clean the drain pump and you discover the pump to be clear, check the drain lines (especially the line running from the bottom of the wash tub to the inlet side of the pump). If all these preliminary checks don't solve the problem, the manufacturer recommends replacing the drain pump.
If this is not what you were talking about, please post back and elaborate a bit more so I can understand the problem you are having. I hope this helps you.
Posted on Jun 23, 2009
  • 5 Answers
SOURCE: lint trap
First you need to remove three screws on the front lower panel. This will expose a round "plug" to your right. This is the lint/drain trap. Place a bucket under the plug. Slowly unscrew this plug and aloow the water to drop into the bucket. Make sure your plug is clean and reset it.
Posted on Oct 10, 2009
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Is there a lint trap for this model? If so where?
There is no lint trap on these washers. The manufacturers are depending on the dryer to remove 80% of the lint. The only solution they give is when sorting the clothes separate the lint givers from the lint takers. Hope this helps
Sep 02, 2011 | Kenmore 22422 Top Load Washer
My Kenmore 22642 washer is leaving lint all over the clothes. If i run them through the dryer, that will remove the lint... but some of my clothes don't go through the dryer. I can't seem to determine if...
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
Dec 26, 2010 | Kenmore 22642 Top Load Washer
Where is the lint trap on the front loader
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design.
Eric
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
I just bought a kenmore elite oasis top-loading washer. It was a floor model-i didn't get the manual. Does it have a lint trap and how to I empty it? Thanks.
You must remove the inlet hose to the pump to find the screen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine lint trap
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Where is the lint trap on my top loading kenmore washer??? there is Lint on all my clothes!!!
When you open the door, check on the bottom part of the dryer before reaching your hand into the dryer. But it should be somewhere accessible on the front part of it, so try and look elsewhere if this isn't it
Mar 13, 2010 | Kenmore 22622 Top Load Washer
Kenmore 100 washer leaves tons of lint
Remove the hoses from the pump. The lint trap will be there.
Jun 16, 2009 | Kenmore 22422 Top Load Washer
Kenmore 92274100 washer leaves lint on everything
Be sure to use higher water level on machine, don't overload machine Seperate lint givers from lint attractors. There is a lint catcher mounted on the bottom of the spin basket but it is self cleaning.
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer Kenmore 90 Series
yes it has a lint trapped ..its on the bottom of wash basket,,its part of the wash basket..when the unit washes it traps the lint when the unit goes in to spin it shoots it down the drain,,i dont advice taking that out unless your a tech..now what you can do is fill unit with hot water and about a pint of bleach and let that do the work its also good for pipes,,this technic should have been a process 1 amonth ..
Dec 22, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
77 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
