Question about Uniden DXAI5188-2 Cordless Phone
No dial tone says out of range
Took battery out and putback in and held down hold button still no dial tone the speaker works though not the hand held phone
Cidco
SOURCE: no dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Posted on Jun 07, 2007
funkyjacob
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
  • 32 Answers
SOURCE: I cannot use my phones since Saturday. The phone message on hand
there is a loop coming from handset 1 causing the line to be busy on incoming calls.try removing the battery pack on this handset.i hope this helps
Posted on Dec 22, 2008
  • 84 Answers
SOURCE: Uniden Dect2080 with 5 cordless phones
try using the telephone cord and jack from the phone that is working with the phone that is not working, if it now works the problem is the jack you were using or the phone cord. If that doesn't solve the problem, unplug the AC adapter and the phone cord for the non-working phone and let it sit for a couple minutes, plug them back in then try to make a call.
Posted on Mar 04, 2009
  • 50 Answers
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
Posted on May 28, 2009
Buttons don't make any sound but can hear dial tone, speaker phone doesn't work, phone dies fairly quickly - would this all be caused by bad battery and what is the life of battery in a Panasonic cordless...
First off, try changeing from tone dial to pulse dial and try calling out. If that does'nt work, touch bad is probly bad. As far as the speaker phone it does not work off battery's it works from the main base which is powered from the A/C. And for the battery life, when you have a cordless phone you have to build the life to the battery, what I mean is : first time you charge it for 12-14 hours, after that use the phone and do not put it back into cradle, the battery will hold a charge for 8 hrs, if you use it for 30 mins and put back on cradle untill next use, use another 30 min and continue doing this the battery will build its life to 30 min and always die after 30 min, try to get into leaveing off cradle all day and charge while you sleep and keep off cradle all day.
Nov 07, 2013 | Panasonic Lands Phones
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
My phone is a KXTGA641 - I now get no dial tone and in a few seconds the screen says ''system busy,try again later. What do I do? I cannot find the book that came with the system.
I had the exact same problem. I was ready to take them back. I took all 4 and set them beside the base. I pulled the battery on one of them to reset it. I then held down the locate handset button on the base for 4 seconds. The base beeped for about 30-45 seconds and they just started working. Somehow I believe they got disconnected from the base and needed to be reset.
Oct 24, 2009 | Panasonic Lands Phones
Can not break through dial tone on either hand set
After going around and around and around with YOU people, I finally gave up and took the damned phone back to the store where I bought it. The first store wouldn't take it back, because I had the receipt (which was from early September, 2008 - which was past the 90 days), so I took it to their other location and told them that I lost the receipt. I got a brand new replacement. If the new one should fail to work, I'll take it back again WITHOUT the receipt, and upgrade to another brand. Thanks anyway.
Mar 27, 2009 | Vtech Lands Phones
Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Oct 24, 2008 | Plantronics CS70 Wireless Headset
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
Dec 06, 2007 | GEH5450 Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
No dial tone on handsets
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
Uniden DXAI5188-2 Cordless Phone Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
