Question about Garden
I have a Sears 18 hp ridermower start up good but after run for a half a hour it jus stop ruining like it is out of gas
Like to fine a new or used card 917.254410 ss 0937s06381
  • Garden Master
  • 2,478 Answers
First check the fuel cap for vent plugged.
Posted on Jan 20, 2013
  • 3 Answers
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
SOURCE: Craftsman 17.5 HP 42 in mower stops after approx 1/2 hour of use
I have an 18 HP B&S 42" Craftsman with the same problem. Carb has been rebuilt and fuel filter replaced. Have cleaned the vent hole in the fuel tank cap. Nothing has helped. Choking the throttle will keep it running for a few more seconds but it eventually stalls out only to start again in 5-10 minutes which keeps me thinking its a fuel, not electrical problem. Maybe overheating but how can you tell if its causing vaper lock?? Submitted by Redroadster.
Posted on May 03, 2009
woobie dog
  • 1273 Answers
SOURCE: my sears riding mower stops running when gas tank
Hi, W/D here.
Sounds like you're machine is pulling a partial vacuum on the tank when it is running, and starving itself for fuel. Check the fuel filler cap vent pinhole. If it is plugged, the mower will do just what you're saying.
Best regards, --W/D--
Posted on Aug 13, 2009
  • 138 Answers
SOURCE: i have a craftsman gt 6000 with kohler 18 hp
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Posted on Sep 13, 2009
SOURCE: Early 1990's 12 hp tecumseh runs until hot then backfires & dies
Coil failure! The heat is what triggers it. I bet you that if you take the cover off the engine you will find the remains of an mouse nest. The nest blocked the airflow and damaged the coil.
In the spring the shop I work at gets a lot of this kind of problem. Critters love to build nests where they feel safe from weather and predators. Your mowers engine....is just one of those places.
Good news is: You can easily replace the coil yourself. The part for this style mower is available online....even through ebay! You can do the change yourself and make her good as new!
Just as an aside. You may want to check compression on your engine if it ran hot for so long. Make sure the combustion chamber isnt packed with carbon and oil coking! If you have pull start and notice higher than normal effort is needed to start it might be a sign of this problem.
The fix there is also pretty simple. You just need to order a new head gasket. Hey....while youre waiting for a coil why not wait for a head gasket right?
Posted on Jul 19, 2010
Craftsman 18" chain saw 42cc. Starts and runs fine. Will not idle after running for a while. Will not restart when hot. Will start after the saw cools down.
I had a 2 cycle snow thrower that acted similarly. It needed a new diaphragm. When they get old they act up. I could never see a physical difference between the good and bad one but the new one fixed it. It's a flat rubber part that is in the carburetor. Call Sears parts or visit them on-line to get a parts breakdown of the carb.
Feb 22, 2015 | Craftsman Garden
Motor power suging up an down
Its in the carb linkage which controls the choke and the throttle position..its just a pain to use it.. won;t hurt anything.
hard to imagine people still buy larger items from sears these days..sorry...
Sep 11, 2017 | Craftsman YT 4000 42" Briggs Stratton 24...
Engine stops running
if it was a bad gas or water in the gas the car would not start and if it does start it would run really rough it sound to me like you have an over heating problem doe s the temp gauge say its over heating just before it dies?
Oct 01, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 1977 sears 18/6 garden tractor with a onan engine 917.25191 with less than 200 hours on engine,.it is hard to start,but runs fine once started.It had been sitting in a shed for about 5 or 6...
if the electric fuel pump is mounted higher than the fuel tank it will have problems getting suction. Be sure that it is mounted down on the frame rail (below the fly wheel is a good spot) so that the suction side is always submerged. Otherwise the pump will take awile to supply gas to the carb bowl. It may get it eventually, but it will burn itself up trying.
Oct 02, 2010 | Garden
My new chain saw stop working. is not pulling the gas
If the saw is new, take it back to Sears for warranty repair or replacement. Good luck!
Apr 30, 2010 | Craftsman sears 18" Chain Saw Chain (...
Having trouble to get it running it fires but wont run i have new plugs and cleaned the carbi and fuel on a bolons st 120 1990 modle ridermower
choked? bad gas. gas sitting for only a few months will go bad. Spray some WD40 into carb and try to fire. if it runs replace gas. Check to be sure keyway has not slipped
Mar 05, 2010 | Garden
I have a 9 hp Sears Craftsman chipper vac model 247.799640. it will not start. have tried new spark plug, notice excess gas around air cleaner that covers carb. Any ideas?
if it sat over last winter with gas in it the fuel most likely laquered up causing the carburetor float to stick shut. remove the carb. take off the floatbowl, usually 1 or 2 screws. check the float to make sure it moves up and down freely. than soak all parts in laquer thinner for 2-3 hours than reassemble the carb. and reinstall on motor. it will start and run. make sure the fuel mix needle valve is set 1and a half turns out from being tightened.
Nov 07, 2009 | Toys
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
