Question about Printronix Office Equipment & Supplies
Printronix p5005 version 4 firmware
Firmware
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
Go to manufacturer site & download 364221.exe file
Posted on Jan 08, 2015
  • 57 Answers
SOURCE: Firmware reqd 352326 firmware download
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter
This should resolve the issue.
Regards,
Lawrence
Posted on Feb 08, 2008
  • 10 Answers
SOURCE: I cant not print from Printronix P5005B on XP. It prints garbage
install generic printer driver
Posted on Aug 28, 2009
SOURCE: textos distorcionados
page to printing dots problem
Posted on Oct 07, 2010
printertech1
  • 96 Answers
SOURCE: a have printronix p5005 printer but printout not
Remove the black cover over the shuttle and look for a phase number hand written in blue marker on the right side of shuttle. Press the up and down arrows at the same time to unlock the control panel. Press left arrow to go to diagnostics. Down arrow and right arrow until phasing. Set phasing number same as what was written on shuttle assy.If it is making noise then the shuttle is bad.
Posted on Oct 13, 2010
  • 12 Answers
SOURCE: My Printronix P5005 is having
tell me its graphics printing or plain Text... if plain text then change CPI like 15Cpi / 17.1Cpi / 20Cpi/ and also change Ignore CPI in Hosts menu...for graphics u can;t do anythigns..
Posted on Feb 07, 2011
Where can I download Printronix P5210 firmware? Printer is no longer supported by Printronix
Depends on the code needed, I configure CMX boards in-house and ship them out all the time. Just need a config from your printer in order to match it up. cardenas_rory@hotmail.com
May 05, 2014 | Printronix Line Matrix P5210 Printer
Printronix p4280 making noise
Depending on the specific circumstances, of course, the most likely culprit is the shuttle assembly. It could either be the motor in the assembly or the bearings in the shuttle assembly.
Put in hold mode. (Press Enable/Hold button)
Remove the shuttle cover assembly. (leave the screws in the cover itself when you remove it). On the middle-right side you will see a cover sensor -- you will need to fool this with a magnet.
Run a test print (Print Test button). (With the hood up/) Listen for the source of the noise. Is it the motor or the shuttle assembly bearings. (If the noise stops when you turn off test print and the motor is winding down then it is the shuttle assembly bearings.) Or is the noise elsewhere?
If elsewhere move around side to side to differentiate and locate the sound.
Here is a link to the part of the manual that describes replacing the shuttle assembly.
Please note that the motor itself is not really considered a separate field replaceable unit -- it is considered a part of the shuttle assembly. I only mentioned it separately above as part of the troubleshooting to consider the noise source. http://www.theprinterplace.com/printronix/P4280_Shuttle_Replacement.pdf
Jul 21, 2012 | Printronix P4280, P5005, P5008, P5009,...
My Printronix P5005 is having problem in printing setting. it prints out of paper. i want to adjust its printer setting. please guide me how i can change printer setting. thanks Tahir
Jan 27, 2011 | Printronix Line Matrix P5005B Printer
A have printronix p5005 printer but printout not clear
Sep 13, 2010 | Printronix Line Matrix P5005B Printer
My printer not printing a one column of the paper
if your printer is line matrix p5005 model then the problem is only regarding the hammer module so for that open the shattle and the check whether the module is ok if it is then cleaned the surface of module with soft cloth and again place the module properly and tight the screw and then only check. u can do one more thing u can use the all black command also . from pankaj
Aug 28, 2009 | Printronix Line Matrix P5005B Printer
Please contact me I can help you out.
Rory Cardenas
Midrange Repair and Parts
Alsip Il 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jun 04, 2009 | Printronix Line Matrix P5005B Printer
Security code violtion eorror of printronix p5005b line matrix printer
You have probably tried to reflash the printer with a firmware level that the printer does not support for that Security PAL. Printronix requires a specific Security PAL to 'unlock' the firmware so you can use the printer. I would get the original firmware for the printer or purchase the upgrade if you are trying to get some specific option to work.
May 11, 2009 | Printronix Line Matrix P5005B Printer
Printronix P5209 or Proline 5 Series
when printer powering on, printer gives message "15V CTL FAILED SEE MANUAL"
May 15, 2008 | Printronix Line Matrix P5005B Printer
Regards,
Lawrence
Feb 08, 2008 | Office Equipment & Supplies
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
